ITR Throttle Body
Old Mar 2, 2008 | 10:26 AM
Chris.B.'s Avatar
Default ITR Throttle Body
My car is getting tuned this Thursday and the only thing that I'm not pleased w/ on my setup is the throttle body. It's currently a stock B20 throttle body w/ ITR intake manifold. Would I benifit much upgrading to an ITR throttle body? Here's my setup..
1995 B18B Block
Bored Over .25 w/ Fresh Hone
Decked .004
New OEM Honda P30 Pistons .25 O/S
New OEM Honda O/S Piston Rings
Shotpeen LS Rods
Rods Resized w/ ARP Rod Bolts
ACL Bearing Set
New OEM Type R Oil Pump
New OEM Type R Water Pump
New OEM Type R Timing Belt
Rebalanced Rotating Assembly
Micropolished Crank
ARP Headstuds
1999 B16 Head
Port & Polished
Milled .004
New Valve Job
Ferrea Valves
Ferrea Springs & Retainers
Buddy Club IV Cams
AEM Tru Time Cam Gears
Type R Intake Manifold
Hondata Intake Manifold Gasket
RC 310 Injectors
Full-Race Ls/Vtec Kit
B&M Fuel Pressure Guage
Hytech Replica Tri-y Header
Apex’i World Sport Exhaust
OBD1 GSR Engine Harness
P28 ECU w/ Hondata S200
Thanks,
Chris
Old Mar 2, 2008 | 12:10 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: ITR Throttle Body (Chris.B.)
Out of everything you listed, this is the only relevant stuff we needed to know:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris.B. &raquo;</TD></TR><TR><TD CLASS="quote">
1995 B18B Block
Decked .004
1999 B16 Head
Port & Polished
Milled .004
Buddy Club IV Cams
For everyone reading this post, it's great to tell us what your build is but when you see like 5 of these "build" threads pop up almost on a daily basis, it makes it hard to sort through all the irrelevant parts and information. Just list what actually matters to the question being asked.
To answer your question, most throttlebodies don't really add (or subtract) a lot of extra HP if they're the wrong size. The best thing to do here is experiment with a larger throttlebody on your car, when it's on the dyno and see what it likes. Either way, it's not like this decision is going to cost you a lot of power if you're running something slightly smaller than ideal.
Old Mar 2, 2008 | 12:52 PM
Chris.B.'s Avatar
Default Re: ITR Throttle Body (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
This is not a build thread.. I copy and pasted this from my build thread. It's a lot easier and faster.. If your tired of seeing these threads then stop reading them. Thanks for your input man.
Old Mar 2, 2008 | 01:13 PM
00Red_SiR's Avatar
All Motor Mentor
This is not a build thread.. I copy and pasted this from my build thread. It's a lot easier and faster.. If your tired of seeing these threads then stop reading them. Thanks for your input man. </TD></TR></TABLE>
It's not a build thread but what you cut and pasted is. It may be faster for you but it's not faster for the people trying to read it and help you. Be glad that I'm not as tired as everyone else is from seeing or trying to sort through threads like this or you'd still be sitting here with no replies...
Old Mar 2, 2008 | 01:47 PM
Chris.B.'s Avatar
A local guy in my area has an ITR throttle body for sale. It's just a few days until I go to the dyno and was wondering if I should spend the extra $100/$150 to match the throttle body to my intake manifold.
00Red_SiR ill take your suggestion into consideration next time. So your telling me to just buy something bigger than the ITR? What size would you suggest?
Old Mar 2, 2008 | 01:55 PM
00Red_SiR's Avatar
All Motor Mentor
Did you happen to measure the B20 throttlebody size by chance? I'm not sure you'd have to port match the ITR stock throttlebody size to your current intake manifold. I had my stock TB bored out by MAXBORE and it perfectly matches the stock size of my Skunk2 type R manifold. I'm thinking a 68mm TB would be a good size for you but the dyno could prove that.
wist00s2k
Feb 28, 2015 10:04 AM
wasanissanFL
11
Feb 19, 2015 11:08 AM
vtecobsession
22
Aug 27, 2008 04:41 AM
99SlammedCivic
57
Jul 1, 2008 04:48 PM
Chris.B.
Mar 5, 2008 09:29 PM
