HELP with TPS and MAP plugs/wires
Old Mar 2, 2008 | 09:54 AM
d16rice's Avatar
Default HELP with TPS and MAP plugs/wires
I have a '97 civic with a D16Y8.
I had my sensors unplugged, and now I have no idea which goes to TPS and which goes to MAP.
Both plugs have Yellow, Green and Red wires.
Can someone be more specific as to which plug goes where? ...just by looking at it? The wires do have different color stripes on them, but I couldn't find any reference to them.
Old Mar 2, 2008 | 10:50 AM
lluks_844's Avatar
Default Re: HELP with TPS and MAP plugs/wires (d16rice)
i usually guess, and if im wrong i can tell by how the motor will idle and run.
Old Mar 2, 2008 | 10:58 AM
jax97hx's Avatar
Default Re: HELP with TPS and MAP plugs/wires (lluks_844)
DONT JUST GUESS !! by plugging them in backwards and turning your ignition on you can burn up a chip in your ecu!! which can cause trouble down the road.
my service manual says this
tps = r/b , y/bl , g/b
map = g/w , r/g , y/r
Old Mar 2, 2008 | 10:59 AM
jax97hx's Avatar
Default Re: HELP with TPS and MAP plugs/wires (jax97hx)
if these colors dont match , which they should ..ill go look at my car n see
Old Mar 2, 2008 | 11:52 AM
d16rice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jax97hx &raquo;</TD></TR><TR><TD CLASS="quote">DONT JUST GUESS !! by plugging them in backwards and turning your ignition on you can burn up a chip in your ecu!! which can cause trouble down the road.
map = g/w , r/g , y/r</TD></TR></TABLE>
Thanks
Looks like that's it.
JasonHi
17
Jun 18, 2020 06:34 PM
racerx3kgt
Apr 11, 2009 10:57 PM
SiR18EG
Nov 6, 2008 02:06 PM
skrewdlude
Mar 5, 2003 08:08 AM
