88 crx hf no start need help kind asap
Old Mar 2, 2008 | 06:30 AM
seeareex's Avatar
Default 88 crx hf no start need help kind asap
ok guys, tried search no results, i i just got a really cheap motor for my car, that i know is good, its a d15b7, its out of a 94 civic, i swapped it in yesterday, it will crank and turn over, but no start, getting, fuel, getting spark, i got one loud a$$ backfire, is it possible to put my dizzy on backwards, also im using my stock b6 dizzy, dont think that makes a difference
Old Mar 2, 2008 | 06:40 AM
Outsane's Avatar
Default Re: 88 crx hf no start need help kind asap (seeareex)
are you using your old dist. or the 94?
ecu codes?
Old Mar 2, 2008 | 06:46 AM
seeareex's Avatar
yea quick rundown using the 94 motor, switched injector plugs to use the 94 inj.(hf ones are ***** wussy), running the 88 hf dizzy, usind the 88 hf wiring harness, and the 88 hf ecu
Old Mar 2, 2008 | 08:25 AM
jlicrx's Avatar
Default Re: (seeareex)
did you remove the injector resistor box from the wiring?
Otownking10
Feb 27, 2010 10:44 PM
hatchboy1
Jun 17, 2008 03:14 PM
Sampsonite987
Mar 27, 2004 06:47 AM
ITSTOCK
Nov 12, 2003 04:53 AM
