94 GSR wont start unless i push start it
I got a 94 gsr teggy, For some reason i was racing one day and the car shut off on me. then all of a sudden i couldnt turn it on, Now when i put the key in the ignition and i turn it makes a click noise so i thought it was the starter so i put a new one and it still act the same i checked all the grounds fuses and everything, the car will only start when i push start it, can anybody help me please, tired of push starting a car everywhere i go ,
Seems you have the same problem as me, my 98 gsr does this when i race recently in fact earlier today i eather push start or just wait like ten mins. I beleive its the alternator im gonna go to auto zone and test it but im sure thats the problem from my research!
could be the starter is bad dont matter if its new but i also had the same problem n it was the battery was no good i would have enough power for lights radio etc but once i turn the key all i got was click
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_9 »</TD></TR><TR><TD CLASS="quote">Could be that or your ignition/ignition wiring.</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaCuRa »</TD></TR><TR><TD CLASS="quote">could be the starter is bad dont matter if its new but i also had the same problem n it was the battery was no good i would have enough power for lights radio etc but once i turn the key all i got was click</TD></TR></TABLE>
yeah dude thats the problem i'm gettin right now...i wanna get a new battery cuz my theory about my problem is that maybe only like 5 outta the 6 cells are workin properly...which could cause the car to not start..either that or it could be as simple as corroted battery terminals or terminal connections...wen u can't start your car, try jumpin it...if it jumps no problem, then it could very well be your battery...let me know how it goes...good luck bro
When you replaced the starter.. did you make sure the starter ground wire was hooked up.. This would prevent the car from starting..
Also.. check the starter backup fuse, and other fuses in the car and in the engine bay.
Try charging the battery for a couple hours and see if it will crank also.
I have the same problem with my 94 gsr swap in my EG, i replaced the alternator, fixed battery drain issues and it still wont start so today im going to get a starter and replace it, ill keep you guys posted, im 90% sure it is the starter. too bad everything is closed today
I have the same problem 98 gsr but i noticed it does this when i fill up my tank even half its weird my alternator was checked at auto zone battery and starter are fairly new anyone know whats going on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkaiWu »</TD></TR><TR><TD CLASS="quote">are all battery the same or are some better then others? very noob question but need answer
some batterys are better, but if you have a stock car, any replacement battery will do fine
</TD></TR></TABLE>some batterys are better, but if you have a stock car, any replacement battery will do fine
i work at acura locally, make sure you dont have a factory immobilizer (fancy word for an alarm that doesnt make noise). it will click or sometimes crank but will not give you any spark, ie. wont start. sometimes over reving the alternator will create too much voltage and freak out the immobilizer. not positive but just had a 98 gsr in my stall with the same problem.
EJ1 wilcox
Apr 25, 2005 02:25 PM
