Paint thinner on plastic sideskirts?
Old Mar 1, 2008 | 10:11 PM
ferio252's Avatar
Default Paint thinner on plastic sideskirts?
So I was respraying my sideskirts black, and they didn't turn out the way I wanted them to. Should I use paint thinner and start over? Does paint thinner ruin plastics? Suggestions?
Old Mar 2, 2008 | 04:39 AM
IMPATIENT's Avatar
Default Re: Paint thinner on plastic sideskirts? (ferio252)
what kind of paint did you use ? spray paint from a can, or real automotive paint and clear ?.
in general you dont want to use harsh stripping chemicals on plastics cause of the possibility of seaping or bubbling. paint stripper doesnt evaporate well, it tends to soak into the plastic. personally id just start sanding them. once you sand plastic you also need to use a certain cleaner that will get rid of the oils released by the plastic once its sanded.
Old Mar 2, 2008 | 06:41 PM
ferio252's Avatar
Default Re: Paint thinner on plastic sideskirts? (IMPATIENT)
i used regular black spray can paint. It was called plastic restore paint by dupont. Yahh I guess i'll start sanding it. thanks.
VegasEg8
Paint and Body
Sep 11, 2014 09:30 PM
EM1 Resto
Paint and Body
Feb 24, 2010 01:03 PM
rewerbcrx
Paint and Body
Feb 23, 2008 12:11 PM
jaydem7
Paint and Body
Sep 11, 2007 10:52 AM
Rising sun #1
May 6, 2003 11:49 AM
