Quick Hood question
Old Mar 1, 2008 | 07:46 PM
88'CRXsi's Avatar
Default Quick Hood question
I'm getting a B16a2 swapped in my CRX soon and i know the stock hood will hit it if i get the ZC hood will it still hit or do i have to get the SIR (usdm) hood, but untill i get the money to get one of those how do i lift the stock hood up so it doesn't hit the motor? thanks
Old Mar 1, 2008 | 08:27 PM
LowFlyin''s Avatar
What mounts do you have?
Old Mar 1, 2008 | 08:31 PM
88'CRXsi's Avatar
Default Re: (LowFlyin')
The Hasport EFb2 mounts
Old Mar 1, 2008 | 08:35 PM
itzmrmonkey's Avatar
Default Re: Quick Hood question (88'CRXsi)
should clear fine
Old Mar 1, 2008 | 08:38 PM
''Simon'''s Avatar
Default Re: (88'CRXsi)
just put like 4-5 washers on the back to bolt on the hood (closest to the window) and make sure that that they r in between the hood and the lever. thats all ull have to do. dont need a new hood.
i have the same mounts in my 4-door with b16 and it hit with normal. and i rased it up an i dont have any problam. g/l
Old Mar 1, 2008 | 08:55 PM
88'CRXsi's Avatar
Default Re: (''Simon'')
Sweet thanks for the help guys
Old Mar 2, 2008 | 06:50 AM
LowFlyin''s Avatar
When I had a B16A2 in my CRX w/ Hasport mounts, the stock hood cleared without spacing. Now, I have a B16B w/ Innovative mounts, and I had to cut a little 6 sq.in section to clear the corner of the valve cover.
Old Mar 2, 2008 | 08:21 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowFlyin’ &raquo;</TD></TR><TR><TD CLASS="quote">When I had a B16A2 in my CRX w/ Hasport mounts, the stock hood cleared without spacing. Now, I have a B16B w/ Innovative mounts, and I had to cut a little 6 sq.in section to clear the corner of the valve cover.</TD></TR></TABLE> B16B has an increased deck height, that sounds about right on hitting a bit.
94CoupeNY
17
Jan 25, 2013 05:14 PM
sloweredcivic
13
Mar 9, 2010 03:16 PM
CivicB18C1
56
Dec 15, 2004 12:14 PM
rhetorical
18
Sep 14, 2004 09:32 PM
CRX Si
12
Sep 27, 2002 08:38 AM
