Putting in my new JDM audio console into EG
Old Mar 1, 2008 | 07:15 PM
fitbmx86's Avatar
Default Putting in my new JDM audio console into EG
so im doing it probbaly tomorrow, if i move my head unit down there will i have to lengthen wires? and unforutnatley i don;t have any type of block off plate right now im planning on putting my gauges once i go turbo up where the radio is located currently, what do you guys use as a like plate to cut and install them in either area.
Old Mar 1, 2008 | 07:32 PM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Putting in my new JDM audio console into EG (fitbmx86)
The wires should not need to be extended.
Old Mar 1, 2008 | 07:56 PM
Untamed_Hatred's Avatar
the wires dont need to be extended unless the original harness has been cut
Old Mar 7, 2008 | 07:07 PM
prplhrtcivic's Avatar
Now that I found a Honda OEM block off plate at the junkyard (lucky!), I don't want to put a plate there! But what I used was a thin sheet of aluminum from Home Depot that I bent into proper shape then just fabbed up some brackets mounted to the rear flaps, out of sight.
Another option I was looking into is I pulled a bunch of DIN size stuff from the junkyard and was just going to use it (and it's clips, etc) to fab something up.
The only part that has to be "pretty" is the face.
Old Mar 7, 2008 | 08:27 PM
JSPECSIR's Avatar
Default Re: (prplhrtcivic)
i took the pocket that comes with the console and traced it onto abs cut out the abs and it just pressure fits in the radio hole. then you can mount what ever you want in the abs. and you can use a standard double din honda multi kit in your console opening to mount your radio in. i suggest the ai hon-k828 as it is better quality and look than metra and scoche kits for honda.
Old Mar 8, 2008 | 07:07 AM
That's interesting. I managed to drill through the side brackets of my center console and screw into my deck, and it's plenty secure, but could be a little bit cleaner. JSPECSIR, you're saying that kit will fit right into the JDM console opening for EGs? That would be ideal.
As it stands, the fit is kind of tight, and I can't mount the trim ring.
Old Mar 8, 2008 | 02:56 PM
JSPECSIR's Avatar
here ya go. click to enlarge. these are really old pics.
egrunner
May 12, 2015 02:38 PM
ej6hatchie
Mar 19, 2008 10:56 AM
GdmLaz
Feb 28, 2006 09:05 AM
TEAM SL
Aug 19, 2004 06:38 AM
Myh4tch
Jan 29, 2004 09:10 AM
