h22a swap tips/concerns?
So after long pondering and thinking I am going with a jdm h22a swap to replace my broken h23
I'm getting the motor from jdmtigerjapanese.com, heard quite a few good things about them I won't be getting the lsd right away. however i will about a month after i install my engine
Any tips from previous swappers?
Thanks
I will be doing this at a friends house, we will have all the tools needed.
Thanks
Yeah i know hmotorsonline is a good place to get it from.
But i've decided to go with where im getting it from
thanks though..any other pointers?
Make sure that you replace all nessary parts. And be patient. I did my first swap alone, with help of boards like this one. It took me about a week to do it. But take your time and do it right. GL
My first swap too, however my friend is a licensed mechanic and works in a performance shop. Everything should come necesary with the swap, anything to look out for?
what he means is, replacing the timing belt, tensioner, water pump, seals, and if your budget allows, the pullies also. Also include a full tune up and do a valve adjustment.
If you are planning to install the lsd tranny a month later after the engine swap, I would recommend holding off the swap until you have the tranny and drop them in at the same time (also replacing the clutch at the same time). Otherwise, you are wasting a lot of time and labor repeating many of the same steps. They key is to do things right the first time.
triple confirm your wiring is correct. specifically the vtec wiring. also, definitely go w/ the jdm lsd tranny.. for 250-300 dollars more? And im assuming that would save u on shipping charges, too. oh and check the vacuum nipples/lines.. I had a nipple broken underneath the intake mani that i couldn't see or find. I had an idle surge for over a yr before i found the source. glued it shut, finally fixed idle. **** breaks, when they ship sometimes. ie tps, vacuum nipples.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giant_Bean »</TD></TR><TR><TD CLASS="quote">what he means is, replacing the timing belt, tensioner, water pump, seals, and if your budget allows, the pullies also. Also include a full tune up and do a valve adjustment.</TD></TR></TABLE>
Alright, I'll definitley do all those
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtaylor16 »</TD></TR><TR><TD CLASS="quote">to add to the list giant_bean gave, replace the thermostat, possibly clean out the intake manifold and egr is you have time</TD></TR></TABLE>
And these also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT »</TD></TR><TR><TD CLASS="quote">If you are planning to install the lsd tranny a month later after the engine swap, I would recommend holding off the swap until you have the tranny and drop them in at the same time (also replacing the clutch at the same time). Otherwise, you are wasting a lot of time and labor repeating many of the same steps. They key is to do things right the first time.</TD></TR></TABLE>
I would prefer to do that, however this car is my dd also and asking for rides all the time is starting to annoy other people
However we have the time to do the lsd swap at a later time too I just need it to run for a little while
basically I'm turning a crap event into a good one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sup3rd »</TD></TR><TR><TD CLASS="quote">Oh yeah, don't forget the beer and cigarettes </TD></TR></TABLE>
Oh we definitley won't..endless supply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeLuder »</TD></TR><TR><TD CLASS="quote">triple confirm your wiring is correct. specifically the vtec wiring. also, definitely go w/ the jdm lsd tranny.. for 250-300 dollars more? And im assuming that would save u on shipping charges, too. oh and check the vacuum nipples/lines.. I had a nipple broken underneath the intake mani that i couldn't see or find. I had an idle surge for over a yr before i found the source. glued it shut, finally fixed idle. **** breaks, when they ship sometimes. ie tps, vacuum nipples. </TD></TR></TABLE>
Ok will definitley check that also.
Thanks everybody for your inputs
willing to hear more
And these also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtaylor16 »</TD></TR><TR><TD CLASS="quote">it says his current motor is bad</TD></TR></TABLE>
Doesn't mean his tensioner will be bad. I highly suggest you swap your h22 tensioner with a manual tensioner from your old h23. if you dont want to reuse the old one then at least buy a new one!
Doesn't mean his tensioner will be bad. I highly suggest you swap your h22 tensioner with a manual tensioner from your old h23. if you dont want to reuse the old one then at least buy a new one!</TD></TR></TABLE>
Yeah, I'll definitley look into that seeing if the one from the h23 still works
my swap cost:
longblock: $1000
brand new water pump/timing belt from someone on here: $100
Plugs, oil, filter, mtf, coolant, misc things: $80
Clutch kit/flywheel resurfacing: $190
Rear main seal/oil pan gasket: $55
Manual tensioner from h23: free
So about $1425 for me...keep in mind, i bought my water pump/timing belt from someone on here so it was cheaper that going to a dealership...
longblock: $1000
civicgimmic
13
Jun 8, 2004 08:03 PM
