Help! Rims has build-ups..
Old Mar 1, 2008 | 04:49 PM
J_CRX's Avatar
Default Help! Rims has build-ups..
Just recently got some rims shipped from Japan. The paint on the rims was peeling and oxidated. So I stripped the paint in attempt to restore the rims. After stripping the paint, I've found some build-ups that I was unable to remove with household chemical like Simple Green, Lime/Calcium removers, etc. Has anyone successful did this themselves and have an answer to remove it. I like how the rims are with the paint stripped, so I decided not to repaint them. Thanks.
Here are some pictures so you'll know what I'm talking about.
Before paint was stripped.
After paint was stripped.
Old Mar 1, 2008 | 05:03 PM
Danronian's Avatar
Looks to me like aluminum oxidation. It happens on lots of aluminum OEM wheels that the paint/clear chips off of and when the brake dust eats at them.
If it is that, which it appears to be. Only sanding/buffing them will make that smooth again without the corroded spots.
Old Mar 1, 2008 | 05:46 PM
jonshonda's Avatar
Community Builder
It might be some epoxy primer that is has held on to the metal!! I used Aircraft stripper to get it off, and it may take a couple trys to get it ALL off!! GL
Old Mar 1, 2008 | 05:59 PM
95greenlude's Avatar
Default Re: (jonshonda)
it just looks like you didnt strip off all the paint.....
Old Mar 1, 2008 | 11:03 PM
J_CRX's Avatar
Default Re: (95greenlude)
All the paint are actually gone, those are just oxidation or whatever it is. I used Aircraft paint stripper, and actually did it 4-5 times while stripping the paint. I've even left it overnight to make sure the paint stripper penetrated throughly. Any other suggestions or solutions?? Thanks all!!
Old Mar 2, 2008 | 12:42 AM
Crank's Avatar
Default Re: (J_CRX)
sandblasting might take all that off
J_CRX
Mar 2, 2008 06:32 PM
aznxguyx89
Aug 30, 2007 08:49 PM
sjteg
Sep 7, 2003 02:52 PM
JSJ EG6
Sep 11, 2002 10:04 PM
