need help in calculating compression
Old Mar 1, 2008 | 04:26 PM
Teamdiesel's Avatar
Default need help in calculating compression
Hi, I was trying to calculate the compression of some piston that someone suggested would be 12:1 in a particular setup. When I use the calculater I don't get that compression, so I need someone else to do it for me in case I did something wrong. Here are the possible specs:
Pistons
Comp. Height: 1.1805
Bore: 3.3465/85mm
Dome: +2cc
Engine
85mmx87.2
B16 head
Rod length: 5.433/138mm
Stroke: 3.433/87.2mm
Block Height: 7.992/203
Head cc: 42.7
No milling
Elevation: 62 ft above sea level
revs: 9500
Old Mar 1, 2008 | 06:04 PM
Teamdiesel's Avatar
I got 10.9:1 with an oem 3 layer headgasket. Is that figure correct?
Old Mar 1, 2008 | 08:16 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Teamdiesel)
yep, based on the numbers you gave, I got 11.056:1
Teal_Coupe
Oct 16, 2005 05:12 PM
0bd1_Kanobe
Mar 19, 2004 01:30 PM
Bnjmn
Jun 26, 2003 01:08 PM
Nextelbuddy
Jun 20, 2003 11:14 AM
4doorH22
Sep 7, 2001 08:29 AM
