just bought innovative mounts
Old Mar 1, 2008 | 02:39 PM
CRX_RR's Avatar
Default just bought innovative mounts
my ? is. i have the cable to hydro conversion mount kit. the driver side mount doesn't line up with my type r motor. is there a bracket for this. any way i can get one for it.
Old Mar 1, 2008 | 02:52 PM
CRX_RR's Avatar
Default Re: just bought innovative mounts (CRX_RR)
anybody
Old Mar 1, 2008 | 06:39 PM
CRX_RR's Avatar
Old Mar 1, 2008 | 06:44 PM
stocklookin91's Avatar
you probably have the driver mount off a 94 and up motor .You need a driver side 90-93 integra mount
Old Mar 1, 2008 | 09:56 PM
CRX_RR's Avatar
Default Re: just bought innovative mounts (stocklookin91)
is there any special brackets i can buy to change it over instead of buying new mount. because i thought the ones i bought should of fitted.
Old Mar 2, 2008 | 11:38 AM
CRX_RR's Avatar
..anyone no if i do need bracket for driver side mount
Old Mar 2, 2008 | 11:42 AM
Intocable's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocklookin91 &raquo;</TD></TR><TR><TD CLASS="quote">you probably have the driver mount off a 94 and up motor .You need a driver side 90-93 integra mount</TD></TR></TABLE>
I believe this is correct!! Part number 11910-PR3-010.
Old Mar 2, 2008 | 04:48 PM
CRX_RR's Avatar
Default Re: just bought innovative mounts (Intocable)
so where can i find a 93 teg mount
Old Mar 2, 2008 | 04:58 PM
awdgsx96's Avatar
Junkyard, http://www.hondaautomotiveaccessories.com
Old Mar 19, 2008 | 05:49 PM
vtec93accord's Avatar
Im having this same problem with my 94 GSR swap im doing in my EF as well. I was told to get a 90-93 Integra mount bracket that bolts up to the block behind the timing covers, is this true?
Old Mar 21, 2008 | 10:39 AM
CRX_RR's Avatar
hey guys i just got the bracket for the driver side mount from hasport. now the problem is that i can't find the bolts for these. does anybody has this bracket. if you do can you tell me if i could use the 91-93 integra studs?
Anythingbtcivic
Feb 13, 2013 12:37 PM
DeeCeeTwo
Jul 19, 2005 11:32 PM
hothotpete
Nov 22, 2004 11:12 PM
Neldawg
Jan 13, 2004 08:53 PM
