Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
I need a few echc ?'s answered
Old Jul 6, 2002 | 01:55 PM
slivic's Avatar
Default I need a few echc ?'s answered
If I am running in the H1 class can I:
1. port my head
2. use after market cams
3. use an after market intake manifold
4. use a z10 cross member
The first 3 are so I decide if I am trading my gsr head for a type r head.
Old Jul 6, 2002 | 02:11 PM
drumsy's Avatar
New User
Default Re: I need a few echc ?'s answered (slivic)
1. port my head
1) Head intake and exhaust parts may be matched but cannot be machined beyond 1 inch into the head. Valves and valve seats may be machined (this does not allow valves made of alternate material as OEM).
2) No internal engine aftermarket parts are allowed.
3) Any air intake in front of the throttle body may be used (stock throttle body must be retained). The rules do mention allowing exhaust headers, but do not mention aftermarket intake manifolds. I'd assume the usual rule of thumb falls into place, and if it's not mentioned in the rules, it's not allowed.
4) Unmentioned, therefore I assume illegal.
http://www.honda-challenge.com/forms/rules.pdf
I believe these are all correct, but maybe someone else can verify for me!
[Modified by drumsy, 6:14 PM 7/6/2002]
Old Jul 6, 2002 | 02:17 PM
slivic's Avatar
Default Re: I need a few echc ?'s answered (drumsy)
If you look at the Hybrid rules though it says:
3.8.3 Hybrid Engine Preparation
This section is intended to clarify the engine and drivetrain preparation rules specific to
hybrids.
- The engine, from the top of the engine block “down” to the ground, MUST be
constructed entirely of Honda parts. No aftermarket parts are permitted in this, the
“bottom end,” of a hybrid engine. Engine overboring is subject to the restrictions
listed in section 3.1 of this Rulebook
- “Upward” of the engine block, cylinder head preparation is FREE
o This is limited to the cylinder head itself – items that attach to the cylinder
head (throttle bodies, fuel injectors and rails, etc) are required to be
sourced from Honda parts
- Engine and transmission mounts, and associated components (shift linkages, etc)
required to perform an engine/drivetrain swap, are free
- Engine management systems (ECUs, piggyback computers, etc) are free
Old Jul 6, 2002 | 02:23 PM
drumsy's Avatar
New User
I would then assume the rules I stated would be for H5-H2. As far as the intake manifold, I would think any OEM part would do for H1 only, but still, no aftermarket.
Old Jul 6, 2002 | 03:03 PM
slivic's Avatar
Does anyone know if this:
“Upward” of the engine block, cylinder head preparation is FREE. This is limited to the cylinder head itself – items that attach to the cylinder
means you can port the head fully and run aftermarket cams.
Old Jul 6, 2002 | 03:55 PM
JeffS's Avatar
Karl Shultz karl@honda-challenge.com is the current last-word, but most of this is spelled out pretty-well in the rule book.
Port: Yes
Cams: Yes
Intake manifold: No (honda parts only)
z10: ??? - my guess is it's not allowed... just a guess though
Old Jul 6, 2002 | 04:18 PM
krshultz's Avatar
Default Re: I need a few echc ?'s answered (JeffS)
From the authority...
1. Z-10 whatever arms are not allowed.
2. Non-honda intake manifolds are not allowed.
3. Port work, valve work...whatever you can do to the head within the rules...is allowed
Here is the intention of the rules. Take a cylinder head as you would take it to the machine shop for a rework. No injectors, no nothing...just the head. That head you have in your hands is open...everything else is subject to the ECHC rules and/or the hybrid rules.
As always, email karl@honda-challenge.com for more specifics.
--Karl, who knows the rules are not perfect, but asks you to bear with us since this is our first year...
Old Jul 6, 2002 | 04:23 PM
Warren's Avatar
Wrong-Way Wang
Before you go porting the head, you better read the rules about porting. It's pretty restrictive. No further than 1" into the head, unless you're in H1.
Warren
Old Jul 6, 2002 | 04:44 PM
slivic's Avatar
Default Re: I need a few echc ?'s answered (Warren)
Well that is what I am trying to clarify here.
I have a b18c1 with a fully ported head, stock valves, but a 5 angle valve job. It has crower springs and retainers. It also has a skunk2 intake manifold and a bored stock gsr throttlebody. That is what I have right now. It sounds to me that the only thing I would have to change there is the intake manifold. I could fabricate a type r intake manifold to work.
My other option is to use a stock 98 JDM type r head, toda b's and ctr .25 over pistons and type r rods. I would lose the ported head if I did this though.
Old Jul 6, 2002 | 04:57 PM
Crack Monkey's Avatar
Your head is ok for H1, per the rule that allows free headwork.
Your intake and TB are not legal. The rule specifies head only. So, better get yourself the largest Honda manifold and TB that fits (ITR?). The manifold is subject to the normal HC rules (port matching 1" deep only).
[addendum] I'm not sure "fabricating" a Type-R manifold would be legal. You would have to argue that the work was required to complete the hybridization. Better check with Shultz to be sure - and be specific about what "fabrication" would be required (redrilling, welding, cutting, etc).
[Modified by Crack Monkey, 6:01 PM 7/6/2002]
Old Jul 6, 2002 | 06:45 PM
krshultz's Avatar
Default Re: I need a few echc ?'s answered (Crack Monkey)
Please do.
--Karl
Old Jul 6, 2002 | 07:21 PM
slivic's Avatar
Default Re: I need a few echc ?'s answered (krshultz)
Well Karl,
Would redrilling holes in a type r manifold, or using a gsr manifold flange on a type r manifold be legal? I am just trying to feel out which setup would be better for me. Also using a JDM 4-1 header in a crx requires cutting of the front crossmember so it would be safer to use the Z10 crossmember!! Again I am far from track worthy in terms of my skills, but I would like to compete by next season.
Josh
Old Jul 6, 2002 | 11:12 PM
.RJ's Avatar
.RJ
in my completely un-authoritative viewpoint i would say yes....
Well Karl,
However, by putting on a ITR head, are you really going to gain anything over the ported/polished head you have? Something to think on...
Old Jul 7, 2002 | 07:19 AM
slivic's Avatar
Default Re: I need a few echc ?'s answered (-RJ)
I don't think I will gain anything at all with the type r head, it was mostly legality issues I was worried about. My current setup made 176 hp with full cat, resonator, and muffler. If I bump the compression with jdm itr pistons I could have a hell of a setup, but the gsr intake manifold would restrict me a bit. Either way I need to get some track time first before I start worrying about total horsepower.
Josh
Old Jul 7, 2002 | 07:54 AM
.RJ's Avatar
.RJ
I'd say dont worry about the head, and work on suspension first. Uncork the exhaust and if you see 185 whp i'd say you're in damn good shape
Josh
Old Jul 7, 2002 | 08:06 AM
slivic's Avatar
Well that exhaust was on the 96 coupe. The swap is now in an 88 hf. I need to get an exhaust made for it. It has tokico illumina's and ground control drag coilovers (450f 900r). So the spring rates need to change. Other than that it still needs sway bars. I have 15x7 k1's on my coupe that will end up on the crx. Oh yeah it still has stock brakes, so those of course will be upgraded.
Old Jul 7, 2002 | 08:16 AM
krshultz's Avatar
A redrill is fine under the "Modifications needed to facilitate a swap" clause. Chopping off flanges and rewelding stuff is not, and sounds like a giant pain in the *** anyway.
This stuff is all spelled out pretty clearly in the rules particularly section 3.8 for hybrid cars. Those things that are not clear can be forwarded to me at the email address above.
Old Jul 7, 2002 | 08:46 AM
slivic's Avatar
Thanks Karl, I will mail you if I am unsure of any further modifications.
Josh
Old Jul 7, 2002 | 03:20 PM
Lees Z's Avatar
New User
Track time will be available at CMP August 3 and 4 - and you can meet all the ECHC folk and get your answers -- in person!
Old Jul 7, 2002 | 04:53 PM
Catch 22's Avatar
Default Re: I need a few echc ?'s answered (Lees Z)
And not to be picky or anything, but how about ditching the avatar there Sparky???
I'm finding it hard to be nice and answer questions with you (I'm assuming it's you) shooting a friggin' bird at me.
Old Jul 7, 2002 | 05:14 PM
B18CXr's Avatar
burnouts to YO mother!!!
Old Jul 7, 2002 | 08:28 PM
slivic's Avatar
Default Re: I need a few echc ?'s answered (B18CXr)
Here, now my avatar is a different kind of bird.
Old Jul 7, 2002 | 09:05 PM
.RJ's Avatar
.RJ
yes, this is really more appropriate. Please lose the avitar, and put something more appropriate in its place. Or, we'll just do it for you - your choice.
Thanks, have a bandit day.
RJ
Old Jul 8, 2002 | 05:27 AM
slivic's Avatar
There you go changed once again. Sorry if i offended anyone.
Old Jul 8, 2002 | 06:23 AM
.RJ's Avatar
.RJ
Thanks
I think this thread is dead as well. Thanks for playing
RJ
shivers
Southeast (Sales)
Aug 8, 2006 04:38 AM
johncarlos
Feb 29, 2004 08:58 PM
