bad lower ball joint driver side question
i was inspecting my front lower ball joints and the driver side ball joint needs to be replaced because it was torn in half. I looked at my passenger side ball joint and it was fine. Now my question is do i need to replace both of the lower ball joints or just the driver side which is bad?
You only need to replace the one that is bad...really a ripped boot doesn't necessarily mean that the ball joint is bad, but eventually the ripped boot will lead to ball joint failure. Good luck!
DEL HATCH
Dec 16, 2006 01:57 PM
copperfox
Jun 16, 2005 08:12 AM
