NA h22 dyno
Old Feb 29, 2008 | 09:08 PM
lude98SH's Avatar
Default NA h22 dyno
I figured I would share this in here also.
H22a
BPI velocity Stack
AEM 3 inch intake
68mm AEBS TB
Accord Euro R manifold plenum portmatched to TB and runners ported
PP head
3 angle valve job on intake and radius on exhaust
Skunk2 Stage 1 Cams
Supertech Flat faced valves
Supertech valve springs
Supertech titanium retainers
Single Layer Headgasket
KaizenSpeed BalanceShaft Eliminator kit
Lightweight Flywheel
UR ultra R crank pulley
Camp1320 header (open)
The car was tuned by Jeff Evans.
Old Feb 29, 2008 | 09:21 PM
nomotor's Avatar
Default Re: NA h22 dyno (lude98SH)
stage 1 or pro 1 cams
Old Feb 29, 2008 | 09:24 PM
lude98SH's Avatar
Default Re: NA h22 dyno (nomotor)
stage 1
Old Mar 1, 2008 | 12:51 AM
GoldLudeRay's Avatar
wow very nice numbers
Old Mar 1, 2008 | 05:30 AM
alterdcreations's Avatar
Default Re: (GoldLudeRay)
nice
stock jdm short block?
Old Mar 1, 2008 | 05:53 AM
lude98SH's Avatar
Default Re: (alterdcreations)
bone stock bottom end
Old Mar 1, 2008 | 06:02 AM
Default Re: (lude98SH)
nice
very rare to come by
Old Mar 1, 2008 | 06:10 AM
b19coupe's Avatar
Nice
Too often we see H22's come in and disappoint.
Old Mar 1, 2008 | 07:58 AM
Shadowz7429's Avatar
camp1320 header! nice
Old Mar 1, 2008 | 08:09 AM
Chris.B.'s Avatar
Default Re: (Shadowz7429)
Nice! Great #s..
Old Mar 1, 2008 | 08:11 AM
quicksilver1689's Avatar
i ♥ snails
good solid setup, i love the torque curve, why does the torque fluctuate up and down through the rpms?
Old Mar 1, 2008 | 08:49 AM
ilikehonda's Avatar
nice numbers, now the real test will be what it runs at the track
Old Mar 1, 2008 | 09:53 AM
ESP.net's Avatar
Default Re: (ilikehonda)
Dynapack... so whats the actual whp?
Old Mar 1, 2008 | 10:03 AM
2fastGSR's Avatar
King of the One Liners
Default Re: (ESP.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote">Dynapack... so whats the actual whp? </TD></TR></TABLE>
Do you think the dynopack has a dynopack to dynojet converter button? come on man.
Packs tend to read a little higher , but nothing outrageous. The real test will be how it powers that pig of a chassis ! !
Great numbers for stage 1 cams, i have seen lower numbers on pro series cams. . . crazy . .
Old Mar 1, 2008 | 10:30 AM
BolivianFuego's Avatar
Default Re: (2fastGSR)
Just incase anyone doesnt know, this was at Jeff evan's dyno apparently, and his dynapack is calibrated to be just at a dynojet. If not lower, these numbers will be the same at a dynojet at least!
Old Mar 1, 2008 | 12:47 PM
lude98SH's Avatar
Default Re: (BolivianFuego)
jeff was impressed to say the least, especially with such a mild build.
Old Mar 1, 2008 | 02:07 PM
4g hatch's Avatar
h22+crx=GAMEOVER!!!!
none the less great #'s. got any money shots? are you gonna take her to the track?
Old Mar 1, 2008 | 02:29 PM
boosted hybrid's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">good solid setup, i love the torque curve, why does the torque fluctuate up and down through the rpms?</TD></TR></TABLE>
Resonance from the AEM intake.
The power that it makes is the actual whp.
This build is on par with k20a2's with rbc/cams/ssr header/3" exhaust and tuning on my dyno. The torque is higher by 10-15 ft-lbs though, I was very impressed. Ambient temps being in the 30's doesnt hurt either.
Old Mar 1, 2008 | 02:32 PM
2fastGSR's Avatar
Default Re: (boosted hybrid)
didnt realize this was on your dyno jeff. . . those numbers are dead on then
makes me want to make an appointment to tune my H , when tim brings his car !
Old Mar 1, 2008 | 03:50 PM
Mike95lude's Avatar
Very, very nice; such a broad powerband, and you don't need to rev it to the moon.
From my research over the years, it seems like the H22 really benefits from UR crank pulleys too. Will you be putting a lot of miles on this engine? I'd be interested in seeing how the bearings do long term. I'm sort of "scared" to run one on mine. Will you be running a full exhaust later?
Old Mar 2, 2008 | 04:44 PM
lude98SH's Avatar
Default Re: (Mike95lude)
well its more of a weekend car so not too many miles. Def under 5k per year for emissions purposes.
Im thinking about doing a 3 inch setup from the collector back after seeing that comparison a few weeks ago.
Old Mar 2, 2008 | 07:58 PM
accordm3's Avatar
nice. I made 227 with type s pistons and stage 2 cams... stock head as far as pnp goes. rmf header and s2s2 cams were the only difference. good job!
Old Mar 2, 2008 | 08:09 PM
AccordSleeperZzZ's Avatar
Default Re: (accordm3)
some respectable power.
props, man.
Old Mar 2, 2008 | 11:56 PM
Mike95lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking about doing a 3 inch setup from the collector back after seeing that comparison a few weeks ago. </TD></TR></TABLE>
That's what I am doing too
Old Mar 2, 2008 | 11:58 PM
Mike95lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordm3 &raquo;</TD></TR><TR><TD CLASS="quote">nice. I made 227 with type s pistons and stage 2 cams... stock head as far as pnp goes. rmf header and s2s2 cams were the only difference. good job!</TD></TR></TABLE>
Very nice . Was that open header or full exhaust?
