Just degreed my cams. Need some input please
Old Feb 29, 2008 | 05:24 PM
B16A CRX's Avatar
Default Just degreed my cams. Need some input please
I just finished degreeing my cams and i dont know if its normal to have the exhaust cam at -7 and the intake at +2
Old Feb 29, 2008 | 05:27 PM
Combustion Contraption's Avatar
That would be an unusual setting..
what camshafts?
Old Mar 1, 2008 | 09:24 AM
B16A CRX's Avatar
skunk2 pro 1
Old Mar 1, 2008 | 11:56 AM
TODAwhore's Avatar
Default Re: (B16A CRX)
I would double check it again. That does seem like an odd setting.
Old Mar 1, 2008 | 12:13 PM
Did you lock VTEC?
Old Mar 1, 2008 | 12:43 PM
B16A CRX's Avatar
nope
Old Mar 1, 2008 | 12:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">nope
Old Mar 1, 2008 | 03:12 PM
b19coupe's Avatar
Default Re: Just degreed my cams. Need some input please (B16A CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">the exhaust cam at -7 and the intake at +2</TD></TR></TABLE>
Run it like that and guaranteed kaboom!
Old Mar 2, 2008 | 04:37 AM
TODAwhore's Avatar
Old Mar 2, 2008 | 07:29 AM
ef92b's Avatar
Default Re: (TODAwhore)
maybe he has one of those VTEC killer cams, LOL
Old Mar 2, 2008 | 10:59 AM
JCushing's Avatar
Default Re: (ef92b)
hey at least he was smart enough to ask....
Old Mar 2, 2008 | 11:03 AM
DonF's Avatar
Default Re: (JCushing)
If you just degreed in the primary's then you are about 4 degrees off on each cam, as they are 4 degrees (centerline) different than the VTEC lobes.
Old Mar 2, 2008 | 01:18 PM
98vtec's Avatar
moderator emeritus
Default Re: Just degreed my cams. Need some input please (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Run it like that and guaranteed kaboom!</TD></TR></TABLE>
hello intake...why....hello exhaust
Old Mar 2, 2008 | 01:35 PM
B16A CRX's Avatar
i couldnt switch the pins in the rocker arms so that vtec would be locked. the only pin that would come off was the pin from the vtec rocker arm . the other pin would not come off is there a special way of removing that pin so i can degree the cams again
Old Mar 2, 2008 | 01:37 PM
98vtec's Avatar
moderator emeritus
do you have access to an air compressor?
Old Mar 2, 2008 | 01:38 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote"> is there a special way of removing that pin so i can degree the cams again</TD></TR></TABLE>
Turn the rocker arm on it's side and tap it a couple of times, the pin should just fall out.
Old Mar 2, 2008 | 01:39 PM
B16A CRX's Avatar
yes i have an air compressor but it is a small one. how many lbs of air is neccesary to lock vtec
Old Mar 2, 2008 | 01:40 PM
B16A CRX's Avatar
i did that. i also tried to pull it out using a magnet no luck
Old Mar 2, 2008 | 02:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">i did that. i also tried to pull it out using a magnet no luck</TD></TR></TABLE>
You just need patience + diligence. If it moves when oil pressure activates VTEC, you can move it.
Old Mar 2, 2008 | 02:26 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
You just need patience + diligence.</TD></TR></TABLE>
Amen, to that.
OP just slow down and go one step at a time. It's not that hard, and GL
Old Mar 2, 2008 | 02:27 PM
B16A CRX's Avatar
ok i will try to do it tommorow. i appreciate evryones help
Old Apr 6, 2008 | 01:04 PM
B16A CRX's Avatar
i just redegreed the cams now. This time i locked vtec. These new settings seem more realistic but i would still appreciate some input. I have Pro 1 cam gears and now its on the +6 line for exhaust and +1 line for intake. The car has a very rough idle and turns off after about 1 min of idling
Old Apr 6, 2008 | 01:39 PM
DonF's Avatar
Pull some fuel on your S300 @ idle.
Old Apr 6, 2008 | 01:45 PM
Chris Tune's Avatar
Default Re: (DonF)
if the idle gets worse by taking fuel, add a bit till u hear the engine idle better... thats if u dont have a wideband of course.
Old Apr 6, 2008 | 01:48 PM
d15Beta's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Pull some fuel on your S300 @ idle.</TD></TR></TABLE>
could this be because the cam generates lesser vacuum? making the idle run rich
