My Check Engine light has been flickering.
Old Feb 29, 2008 | 04:53 PM
shivic's Avatar
Default My Check Engine light has been flickering.
don't give a **** about it anymore.
Modified by shivic at 2:04 PM 3/20/2008
Old Feb 29, 2008 | 04:56 PM
jax97hx's Avatar
Default Re: My Check Engine light has been flickering. (shivic)
hmm.. sounds funny never had a cel randomly flash so ill just bump
Old Feb 29, 2008 | 05:13 PM
HONDACIVC93's Avatar
hmm idk. loose connection somewhere?
Old Feb 29, 2008 | 07:14 PM
ImportCracker88's Avatar
it might be a type 1 misfire....... a catalyst damaging misfire, im not sure for all vehicles.... but some flash once per sec to tell u this, on obd 2 cars(96+) so if u got a b20, is it a 96+ motor....if so check ur cat.
Old Feb 29, 2008 | 08:31 PM
x0!'s Avatar
x0!
i know when this happens on 96 and up vehicles it usually means a random misfire. check your plugs and wires
Old Feb 29, 2008 | 08:48 PM
95sloweg's Avatar
Default Re: (x0!)
what year car and motor? i think it may be a bad ground.
Old Feb 29, 2008 | 10:00 PM
shivic's Avatar
Default Re: (95sloweg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sloweg &raquo;</TD></TR><TR><TD CLASS="quote">what year car and motor? i think it may be a bad ground.</TD></TR></TABLE>
ive got a lstec swap. obdI harness. p28. 95 civic cx.
the cel would flash every now and then. they car would feel like it looses power to the engine when it happened.
I found a bolt that was arching on the starter. then the car ran fine for a day. the hesitation is back now. in fact, the car won't start.
I only throw cel 14 when i jump it. IAC. its a good known sensor too. I'm on the verge of buying another wire harness to see if that fixes the problem.
shivic's Avatar
i've checked all the engine grounds and they are tight.
Old Mar 2, 2008 | 09:53 AM
shivic's Avatar
the car runs but it still [freak]in flickers. and sometimes the motor cuts out.
where does the cel light get its power source.
Old Mar 2, 2008 | 02:30 PM
shivic's Avatar
any thoughts
Old Mar 2, 2008 | 07:33 PM
shivic's Avatar
has this never happened to anyone.
Old Mar 6, 2008 | 12:22 PM
shivic's Avatar
gurus.
Old Mar 7, 2008 | 11:51 AM
shivic's Avatar
come on knowitall's
crapanese
16
Jan 1, 2017 07:33 PM
newyawkballa
Mar 5, 2010 12:13 PM
egturbolsvtec
Mar 15, 2006 03:20 PM
Copy Cat
Dec 25, 2004 03:14 PM
