Can i use a DA booster and master on my ef?
Old Feb 29, 2008 | 04:47 PM
traxxasx's Avatar
Default Can i use a DA booster and master on my ef?
My booster went out, and i can pick up a DA booster with the master for free? Can i use this? Is it a direct bolt up?
91 civic si.
Old Feb 29, 2008 | 05:00 PM
89hatcher's Avatar
yes you can. but make sure you use the non abs unit.
Old Feb 29, 2008 | 06:23 PM
alscrx's Avatar
Default Re: (89hatcher)
90-93 integra booster and MC is a direct fit on EF
Old Feb 29, 2008 | 09:13 PM
sirtef9's Avatar
im running this setup!
Old Mar 1, 2008 | 03:26 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hatcher &raquo;</TD></TR><TR><TD CLASS="quote">yes you can. but make sure you use the non abs unit. </TD></TR></TABLE>
ABS or Non ABS doesn't matter. You can use either one. You just can mix and match ABS booster with non ABS MC.
The non ABS booster will read 260v on the tag on the top of it.
The ABS booster will read 290v on the tag. If you use the ABS setup which I personally know many with this setup you need the nut from the rear line of the MC from the donor car and you will have to cut your rear line and flare the nut on there. Not a big deal
Old Mar 1, 2008 | 08:31 AM
bad306lx's Avatar
Default Re: (sirtef9)
Does this provide any benefit over the stock rex Booster/MC?
Old Mar 2, 2008 | 11:31 PM
JohnnieChimpo's Avatar
Default Re: (bad306lx)
It does matter!! The ABS and NON-ABS will bolt together but they don't work. I've done this. I put an ABS 1inch master on a non-ABS booster. There were no brakes. The 'finger' inside the booster wasn't long enough to engage the master cylinder. I had to make a spacer to make up the difference. If you're going to use an ABS master, you need an ABS booster too.
B_Swapped93
Feb 16, 2017 07:52 AM
95swappedsi
Mar 28, 2004 04:40 PM
spencedogg
Oct 5, 2003 06:06 PM
olddriver
May 1, 2002 07:16 AM
