K series crank pulley bolt
Old Feb 29, 2008 | 02:42 PM
xplicitrix's Avatar
Default K series crank pulley bolt
Is the crank pulley bolt on K series LH thread or RH? Having a b*tch of a time trying to remove the bolt on my K24A4. Tried the impact gun, breaker bar, heating and cooling. Does anyone make a crank pulley holder for the K's? Any suggestions would be appreciated.
Old Feb 29, 2008 | 03:08 PM
b18avtec(A!!M0TOR)'s Avatar
Default Re: K series crank pulley bolt (xplicitrix)
it's left hand thread, yeah i also had a hard time pulling it off. and there is a pulley holder, hope that helps, try a better air gun , a bigger braker bar. i know it was really really hard to break the bolt loose.
Old Mar 1, 2008 | 05:48 AM
A2gt35r's Avatar
You need the crank pully tool $29.00, a breaker bar & a pipe around the breaker bar.
Oh yea it's a 2 man job.
The tool goes into the oversizes hex opening & has a slot for a 1/2 in, cheap & very effective.
Old Mar 1, 2008 | 06:13 AM
b19coupe's Avatar
Default Re: K series crank pulley bolt (b18avtec(A!!M0TOR))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18avtec(A!!M0TOR) &raquo;</TD></TR><TR><TD CLASS="quote">it's left hand thread,.</TD></TR></TABLE>
No, it is not. It is standard right hand thread. Clockwise to tighten, counterclockwise to loosen. Righty tightey/leftey loosey.
Old Mar 1, 2008 | 07:05 AM
Default Re: K series crank pulley bolt (b19coupe)
OH SHI@###T so sorry, i meant the regular way
faran
Mar 30, 2010 05:09 AM
xplicitrix
Feb 29, 2008 03:50 PM
grngsr01
Oct 23, 2005 05:47 AM
yuckymucky
21
Mar 30, 2003 07:04 PM
