Do I need a camber kit for 1.2 - 1.3 inch drop on base 97?
Old Feb 29, 2008 | 01:41 PM
PseuZQ's Avatar
Default Do I need a camber kit for 1.2 - 1.3 inch drop on base 97?
I've narrowed my choice of springs -- sort of. Don't want to go too low. My question is if I use Tein S. Techs, will I need a camber kit as well or is there enough play in the OEM setup to adjust toe, etc?
Thanks.
Old Feb 29, 2008 | 04:24 PM
honda_racing101's Avatar
No you don't need a camber kit for that amount of drop. Just get a good alignment.
Old Feb 29, 2008 | 06:17 PM
PseuZQ's Avatar
Default Re: (honda_racing101)
Awesome! Thanks for your answer.
Old Feb 29, 2008 | 06:26 PM
vinuneuro's Avatar
Default Re: Do I need a camber kit for 1.2 - 1.3 inch drop on base 97? (PseuZQ)
Negative camber is a good thing. You wouldn't want to correct it.
Old Mar 1, 2008 | 08:27 PM
FFXSi4WS's Avatar
Default Re: Do I need a camber kit for 1.2 - 1.3 inch drop on base 97? (vinuneuro)
It's arguable, I am dropped 2 inches and my negative camber causes some pretty horrendous tire wear due to camber , however my car handles considerably better with negative camber , so it's more of a trade off
I am not sure how many degrees you'll be off on your camber but your toe will definitely be off on the front and the back so you'll need to get a good alignment. One of my friends made the mistake of putting it off and he payed for it with some pretty crappy handling for a couple weeks!
Old Mar 2, 2008 | 02:29 PM
PseuZQ's Avatar
Default Re: Do I need a camber kit for 1.2 - 1.3 inch drop on base 97? (FFXSi4WS)
Thanks -- yeah, alignment is assigment one. Changed my mind on the S.techs and went with Eibach ProKit instead. I know there's another thread going about a guy with a Fifth Gen. with Eibachs so I'm gonna follow that closely and then post my own info when I have it.
Dokta
Suspension & Brakes
15
Aug 6, 2008 12:00 PM
vietherbs
May 28, 2006 09:46 AM
MikeyDB7
Mar 13, 2003 03:22 PM
KraZyCHOWMEIN
Dec 19, 2001 07:58 PM
mps9506
Oct 2, 2001 03:47 PM
