noob needs B16A2 Help
Old Feb 29, 2008 | 12:26 PM
nickers's Avatar
Default noob needs B16A2 Help
hey guys im kinda new to the whole swap and civics stuff so go easy on me, This is my situation i just recently purchased and B16 A2 JDM needed a new engine so i decided to get that. So i have to swap done they take forever and i get it back, it has think white smoke comeing from every were and dies every once in a while so i took it back to them and said its not there problem and that i broke it.
so the thing i need help with is what kind of parts do i need.
and if i need a new head or block what kind will fit and what is the best stuff to get.
i have a pretty low budget so any help is great
thanks guys
-nick
Old Feb 29, 2008 | 01:22 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: noob needs B16A2 Help (nickers)
This is an internet forum and because we can't physically see the car, there's no way for us to tell you what's wrong with it. If the shop won't do anything for you, you need to take it to someone else who you trust that can tell you what's wrong with it and go from there.
Old Feb 29, 2008 | 03:07 PM
nickers's Avatar
Default Re: noob needs B16A2 Help (00Red_SiR)
what i mean by my post is if the block is bad and i have to get a new one what would be the best way to go
Old Feb 29, 2008 | 03:13 PM
00Red_SiR's Avatar
All Motor Mentor
either bore it out and rebuild it or change it out with a used one, whatever is easier or fits your plans/budget.
Old Feb 29, 2008 | 03:20 PM
numberone's Avatar
White smoke is usually a blown HG. Check your oil to see if there is water in it. Does the car stutter really bad? Does it misfire? Have you checked your coolant? Do you have loss of power? A Hanes book from autozone will give you the diagnosis for the symptom. That's the easiest and fastest way to find out for a noob or someone with minimal machanical experiance. And if your block is bad, buy an Ls block and go Lsv. Good luck.
junior_ej1
K Series
Jun 24, 2013 04:04 PM
JustAmotor
Apr 8, 2013 04:31 PM
realmadrid6
Sep 12, 2012 03:56 PM
b16_coupe
Jul 9, 2012 06:49 AM
Br1gHtDc2
Nov 13, 2008 07:22 PM
