Need to weld new front radiator support pls help where to do it cheap, socal area.
Old Feb 29, 2008 | 09:10 AM
akusukacrx's Avatar
Default Need to weld new front radiator support pls help where to do it cheap, socal area.
Hey guys,
just like the title says, im around Inland Empire and Orange county Socal.
Pls help if you guys know or can help welding new radiator support for my crx.
I bent mine, the hood, the lights and bumper are not aline right.
Help me pls.
Thank You.
PS: I already have the radiator support, just need to have it weld.
Old Feb 29, 2008 | 10:37 AM
Red_ED8's Avatar
Default Re: Need to weld new front radiator support pls help where to do it cheap, socal area. (akusukacrx)
Are you talking about the T-bar or the hole front core support? If it is the hole core support, and your not that good with a welder I'd say leave it up to a body shop. I just welded on my core support on about 3 months ago it it takes a lot of time and work. But it's up to you, if you want to do it you need to get a spot weld cutter, drill, clamps, and a welder. Pull the old core support as straight as possible (to straighten the surrounding area), drill out all the spot welds (all 100 billion of them), clamp your new core up and check if it all lines up, weld, grind, paint, and your good to go. Still want to do it your self?
Old Feb 29, 2008 | 02:36 PM
akusukacrx's Avatar
Default Re: Need to weld new front radiator support pls help where to do it cheap, socal area. (Red_ED8)
thanks for your info,
i asked local body shop before, they want $650 to do it.
If someone knows a cheap good body shop around inland empire or orange county Socal, pls inform.
Mylinh
Jan 5, 2010 10:54 AM
Draggin99Si
Northern California (Sales)
Aug 28, 2007 08:42 PM
November
Welding / Fabrication
May 16, 2006 06:54 PM
IridiumV
Oct 30, 2005 09:00 PM
msmithgsr2131
Mar 4, 2005 09:04 AM
