help is it posible to use a mpfi obd0 motor with a obd1 ecu
oke here is the problem i got a obd0 to obd1 jumper conversion and i got it all ran only thing thats not hooked up is the vtec because i just want to get it wired b4 i get the motor in when the weather gets better so i got a stock dx motor with a mpfi conversion and i want to know if i can run a p28 with a p06 map in my obd0 car it tryes to start but feels ruff do i need to ajust the dizzy and if so how do i know where to place it to get a good agood start also it idels ruff and stalls wont rev much its seems like its fireing on all cylinders just feels like it fires late
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario_pic »</TD></TR><TR><TD CLASS="quote">will a y8 dizzy be oke </TD></TR></TABLE>
use the dizzy that goes for the motor you are useing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi »</TD></TR><TR><TD CLASS="quote">i would use obd1!dont try the ghetto it up.</TD></TR></TABLE>
If an OBDII distributer bolts better to the head, then THAT would be the better choice.
oke now here is a nother question how do u wire a obd2 dizzy to a obd0 si car lol i got all conbos of plug ends so im able to make a jumper conversion just need the wire outs for the obd0 to obd2
kingkong
May 9, 2005 11:19 PM
DOHClessEF-9
12
Apr 21, 2005 06:07 PM
