Doing a obd2 h22 swap into a 93 obd1 accord.. advise needed...
ok heres what iam trying to run and hoping this will work.
parts from h22
motor ac braket ps braket pump and lines header downpipe
obd1 h23a1 dizzy with external coil obd1 345cc injectors with a p28 chipped ecu "chipped for the 345cc injectors and h22 basemap" still will need to be tuned
will i need the fuel injector plugs from a obd1 prelude for this or will the obd1 accord harness work?
f22 parts
axles and halfshaft all mounts f22 harness with sub harness made for easy wiring of vtec knock iabs ect ect
altenator shiftercables transmission f22 manual. clucth stage 2 lightweight flywheel
ac compressor and lines
also going ahead and change timingbelt balance belt switching from auto tensioner to manual. all front and rear gaskets waterpump.
iam i missing anything here???
parts from h22
f22 parts
hotrodaccord
Dec 15, 2005 01:58 AM
