ITR Motor knocking , help.
Old Feb 28, 2008 | 07:41 PM
Benefitx's Avatar
Default ITR Motor knocking , help.
alright well i was cruising on the highway , i hear the motor start to knock , only has 120k mile...come to find out it was low on oil...
what is the best solution? rebuild it or part out and buy a jdm b18c longblock for 2600$?
Old Feb 28, 2008 | 07:50 PM
R.Kelley's Avatar
Default Re: ITR Motor knocking , help. (Benefitx)
depends on whats wrong with it..
Old Feb 29, 2008 | 06:47 AM
Benefitx's Avatar
Default Re: ITR Motor knocking , help. (R.Kelley)
a spun bearing.
Old Feb 29, 2008 | 08:25 AM
CW-ITR's Avatar
Rebuild it if it'syour own labor. If not, throw in a JDM swap. The nice thing about rebuild is you now have a fresh motor.
Old Feb 29, 2008 | 09:02 AM
dsav4shawn's Avatar
Default Re: ITR Motor knocking , help. (CW-ITR)
Pull motor... new bearings, valve seals, crank, water pump, rings. Machine shop to check out block. GL on the rebuild. Keep an eye on your oil. Just takes time... If I can do it.. anyone can do it.
Old Feb 29, 2008 | 10:33 AM
Benefitx's Avatar
Default Re: ITR Motor knocking , help. (dsav4shawn)
would it not be easier to part out the block+head and use that money towards a new engine and use the money i would use for the rebuild for a whole new motor with 17k miles on it?
Old Feb 29, 2008 | 10:51 AM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benefitx &raquo;</TD></TR><TR><TD CLASS="quote">.....whole new motor with 17k miles on it?</TD></TR></TABLE>17K miles? Hell yeh, go for it. At 17K miles, some body already break-in the egine for you. All you have to do is enjoy the rest of it's life.
Old Mar 3, 2008 | 10:09 AM
Benefitx's Avatar
its a JDM swap...2600$ for the longblock, alls i would have to do is swap some things like IM and pulleys over to the new longblock...is that better than rebuilding it for 1500$?
yaryar
Jan 18, 2008 06:07 AM
kaj
May 11, 2007 09:33 PM
kaj
Apr 18, 2007 09:32 PM
JDM_EK_JOE
May 16, 2006 11:32 AM
