hey need help with my setup
Old Feb 28, 2008 | 07:21 PM
beasty=eg's Avatar
Default hey need help with my setup
hey guys i'm going to build a motor but i got some question about the setup and what will i be looking to get for hp and i would like ur input and advice on the setup
b16 head
skunk2 flat valve
skunk2 springs/ret
skunk2 pro 2 cams
golden eagle cam gear
hondata intake gasket
mild port work
jg victor x intake manifold
68 tb
310 injectors
oem HG
arp studs
b18c1 block 81.5mm
eagle rods
acl bearing
ctr piston
oem oil pump
gsr tranny
act hd
I already check the compression and it was like 12.7.1 so i would like to know is that compression will be ok .the car will get tune and i will drive it like 60% of the time can you guy give me some inputs and advice on what hp i'll be looking to get (I'M JUST WORRY ABOUT THE COMRESSION )
Old Feb 28, 2008 | 10:32 PM
beasty=eg's Avatar
bump............................
Old Feb 29, 2008 | 06:57 AM
st9vex's Avatar
1. Hard to say on WHP, could be anywhere, but I would assume since some head work has been done, you should see 200+ with ease...
2. Which header are you going with this setup? (makes a pretty big difference)
3. As long as it's properly tuned, should be ok to drive
Old Feb 29, 2008 | 08:39 AM
andrewk's Avatar
I think you should run maybe a smaller intake manifold i don't think you'll see the full potential of the victor-x. maybe find a performer-x or even skunk2 since you're running a skunk2 valvetrain/cams.
but yeah i'd see it in the 200+ whp area.
Old Feb 29, 2008 | 09:10 AM
toyomatt84's Avatar
Sanji
Default Re: hey need help with my setup (beasty=eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules &raquo;</TD></TR><TR><TD CLASS="quote">4) E-Racing/Bench Racing/Guess my 1/4 or HP
There is no place for it here, it is not productive, frequently leads to arguments, and is generally pointless. Go find a dyno or a drag strip.</TD></TR></TABLE>
Wayeng
Feb 21, 2011 05:05 AM
Slo96ex
34
Feb 6, 2009 06:26 AM
st9vex
Feb 17, 2008 07:23 PM
Honda_Fanatic
23
Nov 9, 2007 07:54 AM
Ssaacckkeedd
Mar 21, 2007 11:20 AM
