tokico HP/ illumina?
Old Feb 28, 2008 | 07:10 PM
jorkee's Avatar
Default tokico HP/ illumina?
Looking at a new springs/strut setup for my ef hatch and found both of these on Egay at a pretty decent (hopefully) price.
I'm not looking for much of a drop because the roads where i live are garbage, i jsut want better handling... but i need stiffer springs, especially in the back of my car
what do you guru's recommend?
Old Feb 28, 2008 | 08:21 PM
jorkee's Avatar
anybody?
Old Feb 28, 2008 | 10:23 PM
jorkee's Avatar
apparently nobody uses tokico?
Old Feb 28, 2008 | 11:09 PM
Eczema's Avatar
Default Re: (jorkee)
Quick search should answer any questions you have on these. I just got illuminas and tokico springs just cuz its my daily driver and I can adjust them to be soft most of the time. HP's aren't adjustable. Folks around here seem to prefer Koni yellows over tokico in general. That's been my experience anyways -- which is limited. I'm new to this board. Adjustable coilovers give you the advantage of corner balancing so might look into those over regular springs too. Also might consider a camber kit. Like I said, search here, other boards and google. There's a ton of info on this.
Hope you find a good setup
Old Feb 28, 2008 | 11:24 PM
.Manny.'s Avatar
Touching My Member
save up the cash and get the koni. you won't regret it.
do a quick search and I doubt that you will find someone that hated them.
Old Feb 29, 2008 | 12:31 AM
whiteknightef's Avatar
Default Re: (.Manny.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Manny. &raquo;</TD></TR><TR><TD CLASS="quote">save up the cash and get the koni. you won't regret it.
do a quick search and I doubt that you will find someone that hated them.</TD></TR></TABLE>
I personally have owned both the koni's and the tokico's. Unless you are racing stick with the tokico's. They are your best bang for your buck.
Personally I hated my KONI's
I only use TIEN SS w/ solid pillow ball and EDFC (electronic dampening force controller
bigbpatel
Aug 13, 2012 08:10 PM
liquidx
Feb 19, 2007 12:37 PM
supracrx
Suspension & Brakes
Apr 6, 2006 05:53 PM
Vinceg99
Feb 11, 2003 02:34 PM
hondacivic4g
May 15, 2002 03:48 AM
