Do I need a new transmission?
Old Feb 28, 2008 | 06:21 PM
DSBP1's Avatar
Default Do I need a new transmission?
Or do I just need to change the shift cable.....
Everytime my car is cold is hard to change into reverse or to parking,..the shifter gets really hard....when my car is warm is much better, not really smooth but much better......
Is my problem that my transmission is almost going out or just the shifting cable I need to replace?
I have a 94 civic, dx, 1.5L
Automatic transmission, Coupe
Old Feb 28, 2008 | 07:51 PM
jameskersten1's Avatar
have you tried to change the fluid yet?
Old Feb 28, 2008 | 07:59 PM
Thateguhate's Avatar
Default Re: (jameskersten1)
my tranny does the same thing.. I think alot of hondas/acuras do when its cold out... But it shouldnt be as hard as you describe...
Try what he says ^^ and change the fluid.. Preferably with Hondas MTF and see what happens.
Old Feb 28, 2008 | 08:02 PM
R_A_Y_N_E's Avatar
Default Re: Do I need a new transmission? (DSBP1)
If I were you change the fluid first off cuz that is the easist. If it is your transmission you might not necessarily need to replace the whole thing just maybe those gears. It very well could be the shift cable or also the fly wheel
Modified by R_A_Y_N_E at 11:18 PM 2/28/2008
Old Feb 28, 2008 | 08:09 PM
Default Re: Do I need a new transmission? (R_A_Y_N_E)
what about the forks being bent...? Could this be a possibility that its worse when its cold, or would the temperature not have any effect on something like this..??
Old Feb 28, 2008 | 08:28 PM
x0!'s Avatar
x0!
change the fluid if that doesnt help..
good news is people practically give away auto sohc trannys. bad news is they are a bitch to put in
Old Feb 28, 2008 | 08:30 PM
Default Re: (x0!)
oh ****...
I missed the part where he said it was an auto..
Old Feb 28, 2008 | 08:33 PM
jax97hx's Avatar
sounds like the perfect time for a conversion to a 5-speed
Old Feb 28, 2008 | 08:49 PM
thatonekid's Avatar
ill most likely be tossing my auto d16 trans when i do a swap, bad news its going to be a while, ill pm you when i dont need it no more if you want it its a 98
Old Feb 28, 2008 | 09:12 PM
JediKnight4life's Avatar
Default Re: (thatonekid)
if you change ur mind and need an auto tranny i got one in my 95 sedan. im doing a 5 spd swap so i wont need it anymore. you know, if ur interested
Old Feb 29, 2008 | 07:58 AM
randerson0248's Avatar
See if there is a way to squirt some kind of lube into the shift cable. Use something in a spray can with a little straw thing. If straw thing is too short get some very thin vacuum tubing or something. Start at the highest point of the cable and let gravity drain the lube down the cable. While squirting the lube, move the gearshift thru the gears a couple of times, then squirt more lube.
Works on all kinds of cables that are sticking.
Old Feb 29, 2008 | 11:04 PM
DSBP1's Avatar
the weirdest thing is that once it gets warm....it seems fine....its annoying...and no thanks I don't want to change it to a 5 speed..I live in NYC, traffic is a hassle and I can just image my self stuck in traffic jam while getting a work out in a 5 speed....plus I heard that a lot of times when you do the conversation it usually tends to give people problem, especially clutch problems..
and for those people that are selling their trannys, yeah send me a pm,..I'll be willing to buy one from you guys(as long as it is in good condition) if I need to...
and yeah, I changed the transmission fluid and it still does the same thing.....
btw, where do I spray that lube to the transmission cable?? plus usually the transmission cable has some rubber or black thing that protects it....so how can I spray something inside? Also how can I change certain gears? or is this only for 5 speed? how can I find out if it is the forks being bent? fly wheel?
if I ask my mechanic he says is the shift cable....but I don't want to spend money on a shift cable then weeks later my transmission dies*
Old Mar 2, 2008 | 06:19 AM
DSBP1's Avatar
Suppin!
japcat
Mar 11, 2015 03:12 AM
SobrietyRulesNA
Transmission & Drivetrain
Jun 20, 2013 08:18 PM
island_civic
Classic Hondas
Jul 22, 2008 06:50 PM
Diversion
Aug 14, 2006 03:08 PM
boredwild
Nov 29, 2004 10:58 AM
