1996 DX Hatchback: CEL Light Won't Blick When I Try to Pull a Code
So I tried the paper clip trick in the blue harness near the ECU. I turn the car onto 2nd level: the SRS blinks like once, but the CEL doesn't blink at all. I've searched this forum and other forums came up with a couple of theories:
ECU is in recovery mode.
or
Something is Burnt
Extra Info:
Cluster does not work, (i've tried 3 different clusters already, all working FINE.) i'm guessing it's the speed sensor?
above the valve cover is the filter manifold thing... and under it is a plug with a round harness but doesn't go anywhere.
Between the valve cover and the manifold theres a square harness with wires, but a red one is sticking out, i have no clue what that is.
etc: my radiator's reservoir was boiling water to the point where it started to boil out of the reservoir...it got ridiculously hot. I had half a reservoir of water in there, and this morning it was almost all gone. I'm guessing its a clogged hose...but could there be a problem in the radiator causing the CEL to turn on?
it'd be great if i can get some help on this...i need to smog my car in like 5 days to get my sticker, or else im kinda expletiveed.
thanks!
ray
or
Something is Burnt
Extra Info:
thanks!
ray
nah, lol the WHOLE cluster dont work at all...well tach, and speed the CEL SRS OIL BREAK SEAT BELT and others work
blinkers work too... the fuel meter works and sometimes the temp
but as for the speed and tach, NEVER worked...
tried replacing it with my other clusters...same thing
92HB_HB
May 12, 2003 12:23 PM
