SOHC ZC cam gear same as A6?
Old Feb 28, 2008 | 05:30 PM
revikan's Avatar
Default SOHC ZC cam gear same as A6?
Are d16a6 and sohc zc cam gears the same? I have a zc head that needs a cam gear
Old Feb 28, 2008 | 05:40 PM
SIred91's Avatar
Rainman
Default Re: SOHC ZC cam gear same as A6? (revikan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revikan &raquo;</TD></TR><TR><TD CLASS="quote">Are d16a6 and sohc zc cam gears the same? I have a zc head that needs a cam gear</TD></TR></TABLE>
Yes. same.
Old Feb 28, 2008 | 05:56 PM
revikan's Avatar
Default Re: SOHC ZC cam gear same as A6? (SIred91)
thanks
Old Feb 28, 2008 | 06:29 PM
AGP-EG's Avatar
Yep, you know the SOHC ZC is pretty much the same as a D16A6 except the sohc zc has more aggresive camshaft and alot better pistons for higher compression i believe.
I have had a DOHC ZC in the past and now that i look back on it i would rather take a SOHC ZC now then a dohc zc because of the aftermarket support for the D series motors compared to the oddball dohc zc.
Old Feb 28, 2008 | 06:51 PM
Tippyman's Avatar
Default Re: (AGP-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGP-EG &raquo;</TD></TR><TR><TD CLASS="quote">Yep, you know the SOHC ZC is pretty much the same as a D16A6 except the sohc zc has more aggresive camshaft and alot better pistons for higher compression i believe.</TD></TR></TABLE>
Nope, just the cam. And it's barely better.
lunatics209
19
Oct 14, 2007 10:56 AM
RockWolf
17
Jul 25, 2006 10:04 PM
racer-025
15
Jun 9, 2005 04:00 AM
slocrxsi
11
Dec 2, 2003 05:39 AM
crx88fast
17
Aug 7, 2003 04:53 PM
