How to set the TPS
Okay so I have removed both TPS sensors, and Im looking at the TPS and well it looks like its going to be a pain in the *** to adjust it right.
Question
How do I set it properly?
Do i just guess, put it in there where I think it will go good at. Install it and measure the voltage, and if its wrong try and adjust it again?
Yes Ive searche too
Question
Yes Ive searche too
learn how to search and why did you make another thread?
https://honda-tech.com/zerothread?id=2169249
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude »</TD></TR><TR><TD CLASS="quote">learn how to search and why did you make another thread?
https://honda-tech.com/zerothread?id=2169249</TD></TR></TABLE>
Two diffrent Topics
Thanks for thread too, best stuff, it had to offer, was set tps to .45 volts at on postion on ignition and its good.
Modified by Acidcrakker at 10:57 AM 2/29/2008
Two diffrent Topics
You can plug it into the harness, turn on the ignition and adjust to .45V or you can use an ohm meter to achieve the same thing. Measure the outside leads, and adjust so that the ratio of the resistance is 0.45/5.0v. Then tighten those weird screws or replace with some normal kind.
