Suspension & Brakes Theory, alignment, spring rates....
koni yellows...help...help...please
Old Feb 28, 2008 | 10:26 AM
drew1987's Avatar
Default koni yellows...help...help...please
ok is the thing i have a civic hatchback iam putting a h22 in my car.ok now what i been reading on honda tech is that koni yellows work very well with ground control.so what i read about ground controls is that the springs are eibach ones would it be better if i would just buy the springs instead of the coilovers.
or is there somthing that i need from the coilovers to make it fit the shocks.....
Old Feb 28, 2008 | 05:02 PM
allshownogo's Avatar
Default Re: koni yellows...help...help...please (drew1987)
you should be good if you just wanted to put spring on. you would loose the advantage of changing you ride height. jack your car ur and look. struts have a spring seat,the eibach G.C. ( I have em) has the ability to be adjstable which is a plus if you want to change for ride hieght or tweak for the track.
snowblind7x
Feb 23, 2006 11:35 AM
egb18c5
Suspension & Brakes
Nov 8, 2005 09:30 PM
IvTecR
Jan 17, 2004 06:32 AM
EL-Driver
Apr 29, 2002 07:14 AM
