code 9 problem
Old Feb 28, 2008 | 09:05 AM
OneWickedef2's Avatar
Default code 9 problem
i have a 91 civic sedan...car is converted from obd0-obd1 dpfi to mpfi.. i had a d15b vtec with a chipped p28 and i had check engine light code 9 then i swapped it for a ls motor with a pr4 ecu..still code 9 then now i have my ls/vtec which i swapped from my integra running perfect..then still code 9...i had my wiring done at redzone..but he might have sent it into rywire...but he couldnt figure it out also...some help plzz...my car is starting to studder/jerk when i drive it..
Old Feb 29, 2008 | 01:13 AM
RedZone's Avatar
Default Re: code 9 problem (OneWickedeG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneWickedeG6 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 91 civic sedan...car is converted from obd0-obd1 dpfi to mpfi.. i had a d15b vtec with a chipped p28 and i had check engine light code 9 then i swapped it for a ls motor with a pr4 ecu..still code 9 then now i have my ls/vtec which i swapped from my integra running perfect..then still code 9...i had my wiring done at redzone..but he might have sent it into rywire...but he couldnt figure it out also...some help plzz...my car is starting to studder/jerk when i drive it.. </TD></TR></TABLE>
I looked into it some more and i might know the problem...call me up on monday and ill get you back in
Old Feb 29, 2008 | 08:23 AM
gnar kill's Avatar
Default Re: code 9 problem (RedZone)
I don't think a code 9 would cause your car to studder or jerk when you drive it. and since it is happening on two different engines with two different distributers it has got to be your wiring. I had this same problem with my obd1 z6. One wire was just in the wrong spot on the jumper harness I was using for the distributer. Double and triple check your wiring
Old Mar 4, 2008 | 12:12 PM
oic...im gonna double check again..thankz..
Old Mar 4, 2008 | 07:31 PM
ok..so today i went to redzone...and had jeremy check out my wiring again..and at first he just took a glance..but this time..he actually counted..and i was 1 over...so he fixed that problem..so now my car is running perfect like before no more check engine light...thanks to Jeremy at RedZone Performance two Thumbs Ups!!!
toxicsynergy
Jul 29, 2008 05:18 PM
obuhmyuh
Feb 25, 2008 12:48 PM
the.hamburglar
Mar 16, 2006 05:55 AM
crx2ner
Sep 25, 2005 01:00 PM
racingant
Aug 12, 2005 05:12 PM
