81mm 9.0:1 JE pistons for B-series motors
I have a set of JE 81mm 9:1 pistons for any b-series motor. These are brand spanking new and retail for about $500. I have ring sets for 3 of the 4 pistons-- I used the other one on another application. Not to worry though, you can buy the ring set for the last piston for $17 from any JE piston distributor. I only want $300+shipping($15.00). Detailed pictures are available upon request and you can get them by contacting me at TypeSon3@yahoo.com. If you want references, go to http://www.sportsnimports.com I'm a moderator on that site and you can ask anyone there about my credentials.
[Modified by RedHB, 11:15 AM 7/6/2002]
The pistons are 81mm and the stock B series bores are 81mm also, so I guess they would fit. The spec sheet that came with these pistons called for .035" piston-to-wall clearance so keep that in mind when installing these.
