MOVING SALE! B18C1 Built Long Block NEVER RAN!
I'm moving to florida so i would like to sell this ASAP. This engine has <U>never</U> been cranked over since built.
Block
-All work by Jim Justice himself
-Fully Balanced Rotating Assembly (Crank, Rods, Pistons)
-New OEM bearings
-Eagle H-Beam Rods 3/8"
-Custom Arias Pistons 12:1 comp w/
Swain Tech Therm. Barrier & Anti-Friction coatings.
-New OEM Water pump
-ARP Head Studs
Head
-Street Port and Valve Job By Ladd's Machine Shop in Laurel, MD;
Mild Bowl Blend w/ 5-Angle Intake and Radiused Exhaust
-New Manley Bronze Valve-Guides
-Cat CamsHot Street Cams, Mag-Aluminum Retainers, and V-Springs
-OEM Headgasket and Timing Belt
Over $4500 invested, will let go for $3000
<U>NOW EVERYTHING U SEE GOES FOR $3000!</U>
My loss is your gain!
Some new items:
Precision Turbo <U>400cc</U> injectors $150
Walbro fuel pump $75
Skunk2 Cam Gears $150
Skunk2 Manifold for GSR w/o fuel rail, injectors, or TB $100
GSR OBDII Dizzy $100
Modified by Draglab01 at 6:08 PM 3/5/2008
Modified by Draglab01 at 6:09 PM 3/5/2008
Modified by Draglab01 at 6:14 PM 3/18/2008
Block
-New OEM bearings
-New OEM Water pump
-ARP Head Studs
Head
Some new items:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Draglab01 »</TD></TR><TR><TD CLASS="quote">bringing this back to life
everything you see for $3000</TD></TR></TABLE>
dang!
dang!
