FS/FT 1991 Honda CRX HF w/B18A1, Columbia, SC
Old Feb 28, 2008 | 05:11 AM
alupso's Avatar
Default FS/FT 1991 Honda CRX HF w/B18A1, Columbia, SC
Old Mar 3, 2008 | 05:13 AM
alupso's Avatar
Still available
Old Mar 7, 2008 | 06:40 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (alupso)
Starts and runs okay? I am interested, but I don't want to buy a problem either.
Old Mar 7, 2008 | 07:11 AM
alupso's Avatar
Default Re: (RobbieG35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RobbieG35 &raquo;</TD></TR><TR><TD CLASS="quote">Starts and runs okay? I am interested, but I don't want to buy a problem either.</TD></TR></TABLE>
Yes, it seems to start and run fine but vibrates a little. I suspect that is because of the rear mount not being installed. It is also using the PM6 ECU currently because the PR4 I had went bad, I need to recheck the PR4 ECU to see if it was actually bad.
Old Mar 7, 2008 | 07:17 AM
RobbieG35's Avatar
12 Years Strong
Heat, wipers, all that works? Do you have bolts for the rear mount?
Old Mar 7, 2008 | 07:20 AM
alupso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RobbieG35 &raquo;</TD></TR><TR><TD CLASS="quote">Heat, wipers, all that works? Do you have bolts for the rear mount?</TD></TR></TABLE>
Yes, heat and wipers and all the electrical parts work, I didn't touch the wiring at all except to put in a new plug for the radiator fan. One thing I did notice when I was in it the other day is the tach wasn't moving, not sure if it cable came out or not but it was working before. Yes I have the bolts for the rear mount.
Old Mar 7, 2008 | 07:23 AM
RobbieG35's Avatar
12 Years Strong
PMed you.
Old Mar 7, 2008 | 07:29 AM
alupso's Avatar
PM'd
Old Mar 9, 2008 | 12:38 PM
RobbieG35's Avatar
12 Years Strong
PM back at you.
Old Mar 10, 2008 | 01:04 PM
RobbieG35's Avatar
12 Years Strong
Picking her up Saturday!
driveahonda
22
May 22, 2007 11:41 AM
CooBlueDAB
Apr 16, 2007 08:50 PM
rizen
Aug 1, 2005 03:36 PM
Pearl Crx
May 24, 2005 01:23 PM
Crosser
Apr 19, 2005 05:16 PM
