#2 cylinder not firing?
Old Jul 6, 2002 | 06:48 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default #2 cylinder not firing?
it's a d16z6. i swapped the head for the kid because a piece of a valve was cracked from some nitrous dosing and too much advance. it runs much better but is still a little weak and we found that #2 is sparking but not firing. the timing is dead on. i am about to change that injector...even though it is clicking, could it not be getting the fuel? we changed that spark plug. i hooked up a vaccum gauge and it reads 20 which is strong right? so with that, the compression should be good from the pistons? i am going to try the injector but if any of you have any ideas...i'd be glad to hear them.
Old Jul 6, 2002 | 09:52 AM
ionic_slim's Avatar
Default Re: #2 cylinder not firing? (not so civic)
did you do a compression check?
Old Jul 6, 2002 | 10:40 AM
poison's Avatar
Default Re: #2 cylinder not firing? (tazmoe)
after then, see if you are getting spark in the cyl, if you are, take out spark plug in that cyl, and run the motor for a very short time, and smell to see if fuel is being injected.
slowwcivic
May 25, 2011 06:18 AM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
thunderboy
Apr 24, 2010 08:39 AM
WrongSide
Jan 4, 2009 05:34 PM
ksprelude01
Mar 27, 2008 07:05 PM
