how can i?
Old Feb 27, 2008 | 06:57 PM
JDMDC2BOY12's Avatar
Default how can i?
sup guys, i need to change my rear hatch window and i just want to know how i can take out my headliner to unbolt those studs? pics or link would be much appreciated! thank you
Old Feb 27, 2008 | 07:16 PM
Default Re: how can i? (JDMDC2BOY12)
byump help a brother out!
Old Feb 27, 2008 | 07:56 PM
Pat_S's Avatar
Check these threads out. Maybe it can give you an idea how to do it.
https://honda-tech.com/zerothread?id=1938926
https://honda-tech.com/zerothread?id=1939680
https://honda-tech.com/zerothread?id=645371
Old Feb 27, 2008 | 07:58 PM
g2daturbo's Avatar
Default Re: how can i? (Pat_S)
open the hatch pull of the rubber trim and pull down on the back of the headliner..use a 12mm wrench ratchet wrench if u got one and make sure u disconnected the wires going to the hatch the connector will be down on the ps rear of the trunk behind the plastic interior pieces
Old Feb 27, 2008 | 08:49 PM
Default Re: how can i? (g2daturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2daturbo &raquo;</TD></TR><TR><TD CLASS="quote">open the hatch pull of the rubber trim and pull down on the back of the headliner..use a 12mm wrench ratchet wrench if u got one and make sure u disconnected the wires going to the hatch the connector will be down on the ps rear of the trunk behind the plastic interior pieces</TD></TR></TABLE>Can I use the same wiring for a Type-R defroster? How do I take out the headliner? Thanks for all the info!
Old Mar 1, 2008 | 09:02 AM
BUMP
cmilner
May 19, 2010 06:38 PM
DC2FRMDABAY
Feb 17, 2008 01:12 PM
JiZzEr
Mar 13, 2007 06:45 PM
TheTealHatch
Feb 1, 2006 06:00 PM
remove account
Feb 15, 2005 04:37 PM
