jdm da cluster
i need help. my da got jacked and when i got it back and test drove it the rpm gauge works fine but when the other one hits over 20 mph its start to flicker up and down. so i cant tell how fast im going. i can only tell under 20 mph... i need help fixing it. does anyone kno how to fix it? or do i need a new one? the thing is they didnt even mess with it. they didnt even try taking it out..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwuknoit »</TD></TR><TR><TD CLASS="quote">i need help. my da got jacked and when i got it back and test drove it the rpm gauge works fine but when the other one hits over 20 mph its start to flicker up and down. so i cant tell how fast im going. i can only tell under 20 mph... i need help fixing it. does anyone kno how to fix it? or do i need a new one? the thing is they didnt even mess with it. they didnt even try taking it out..</TD></TR></TABLE>
stay under 20 and you will know how fast your going lol
cable may not be seated completely in the speed sensor...check to make sure its in there tight...had this problem on my da bc the clip for the speed sensor was missing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2daturbo »</TD></TR><TR><TD CLASS="quote">cable may not be seated completely in the speed sensor...check to make sure its in there tight...had this problem on my da bc the clip for the speed sensor was missing</TD></TR></TABLE>
x2!
x2!
doubleoazn03
May 29, 2012 03:02 PM
ej2kiid
22
Jul 14, 2011 12:24 PM
90HondaCRXSi
Oct 4, 2009 10:52 AM
