Separating the ECU board from the case?
Old Feb 27, 2008 | 04:28 PM
StorminMatt's Avatar
Default Separating the ECU board from the case?
I have a broken P75 ECU into which I would like to swap a PR4 OBDI board for mounting reasons. It would appear that this is perfectly possible, given the locations of the screw holes, sockets, etc. BUT, it seems like Honda did not think that screwing the board to the case with seven screws was enough to hold it on. They also cemented it on. And trying to separate the board by pressing it off makes some nasty, crackling sounds that I don't like to hear (but fortunately only on the broken P75). Does anyone have any experience with doing this sort of thing? Is there perhaps some kind of solvent that can dissolve whatever glue Honda used here?
Old Feb 27, 2008 | 04:33 PM
Turbogixxer's Avatar
Default Re: Separating the ECU board from the case? (StorminMatt)
I just push by the case with my thumbs. Once you "break" one loose, you are good. Make sure you unscrew the transistor by the ECU plugs
mita
Aug 28, 2014 11:46 PM
reyrey2006
Sep 21, 2008 11:19 AM
MaiSi
Audio / Security / Video
11
Sep 4, 2008 02:38 PM
Hondata
Mar 26, 2002 12:22 PM
