bogging?
I changed my valve cover gasket today.
took off the spark plug wires so I can remove the cover.
I put everything back on, and now car makes a rumble sound and feels extremely slow.
any ideas?
I'm getting spark on all cylinders
car is a 95 civic vx with a 95 gsr motor.
driven daily without a prob for 2yrs..and now this happens...
help anyone?
any ideas?
help anyone?
sounds like firing order to me...
In other words... you have your spark plug wires in the wrong order..
But then again I dont think it would start if you put them in the wrong order.. did you f up the gap horribly on your plugs?
i didnt change the gaps..since i didnt change the spark plugs..i just removed the wires to remove the valve cover...
i looked at my co workers dizzy and mine matches up to the right plug.....
im bummed...
i dunno wsup with it since i didnt do anything to it but change the gasket..
im bummed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks »</TD></TR><TR><TD CLASS="quote">firing order!
not the plugs!!!!
someone get this guy a pic</TD></TR></TABLE>
!!! get me a pic!!!
other dizzy was the same angle as me
did a compression test..all cylinders hitting 200psi
not the plugs!!!!
!!! get me a pic!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sic_DA_Nine »</TD></TR><TR><TD CLASS="quote">thats how i have it
thanks tho
Change your plug wires.
I SWORE I had good wires and fought it. Replaced the wires and it ran 100% better.
thanks tho
</TD></TR></TABLE>Change your plug wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sic_DA_Nine »</TD></TR><TR><TD CLASS="quote">my wires are fairly new...
i guess its time to get another set :[
more money down the drain..
and working 8 hours a week aint helping..
expletive BESTBUY!</TD></TR></TABLE>
No man go to autozone. Return them if it's not that.
before u go out and buy new wires u could always check the resistance with an ohm meter if i rember they shouldndnt be under 17k ohms someone correct me if im wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sic_DA_Nine »</TD></TR><TR><TD CLASS="quote">if the wires are bad, would there be spark going through em?</TD></TR></TABLE>
Yeah, but the "spark" could be going out the side of the boot and into your valve cover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sic_DA_Nine »</TD></TR><TR><TD CLASS="quote">intersted...thanks for the info..i guess imma try that out tomrrow...
will any b series wires work?</TD></TR></TABLE>
That I don't know. When mine went bad I used some extra Small Block Chevy wires I had.
(It was really only one wire that was bad)
yes
yes
LOLOL nice and simple<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320spTurtle »</TD></TR><TR><TD CLASS="quote">
BAM!</TD></TR></TABLE>
