FS: 98% Complete DA/DB '90-'93 Integra 2/4 door turbo kit GSX Turbine
<U>I WILL NOT PART OUT THE INJECTORS OR ANYTHING ELSE!!!</U>
Ok, so went to court and they decided to pop up with another ticket out of nowhere, so now I must make a sacrifice and sell my turbo kit.
Here are the details:
-GSX Td05 Turbo/Compressor/Housing, internal stock wastegate
-2.5" Downpipe with o2 bung
-Custom log manifold
-Manual boost controller
-Greddy Type R BOV w/ flange
-Autometer boost gauge with MSD bracket
-450CC DSM Injectors peak and hold injectors
-fuel injector Resistor box (if needed)
-Missing Link (needed for the MAP sensor)
-Cheapy side mount intercooler
I think that's everything. I just don't have the intercooler piping, or the oil feed/return lines.
This is a custom kit made to fit the '90-'93 Integra. Only things you gotta do is notch the crossmember, grind the little tab off the block, and get a slim fan. Everything else works fine.
Also this kit will let you keep your AC and PS if routed right.
<FONT SIZE="5"><FONT COLOR="red">$650</FONT></FONT>
Housing...
Compressor/housing/manifold/dp...
Greddy Type R BOV...
Cheapy manual boost controller...
Cheap side mount intercooler...
DSM Black Top 450CC injectors (SAME EXACT THING as the blue top, only difference is that green cover for "dual spray")...
Missing link for MAP sensor...
Modified by denraweb at 1:22 PM 2/28/2008
Modified by denraweb at 1:23 PM 2/28/2008
Modified by denraweb at 12:17 AM 2/29/2008
Housing...
Spoon84
Jan 7, 2009 06:04 PM
civicboy34
Mid-Atlantic (Sales)
Jan 18, 2007 08:22 PM
civicboy34
Jan 17, 2007 10:48 PM
B_Series_4_Life
Northern California (Sales)
Mar 21, 2006 09:36 AM
