OBD1 injector question.
Are OBD1, EX and DX injectors the same?
My obd1 jdm d15b swap is studdering when I accelerate.
It is converted to obd1. I was going to try to swap out the injectors with some from a 92 civic/hatch dx, but I want to know if they are the same.
Or does any body have any suggestions?
It is converted to obd1. I was going to try to swap out the injectors with some from a 92 civic/hatch dx, but I want to know if they are the same. Or does any body have any suggestions?
Thanks! :thumbup
Ill swap them out tommorrow.
I also read some where here on honda tech that if you don't swap the two wires on the map sensor it could cause the car to react like this. Is this true? Maybe they forgot that step.
Thanks again drlatino999.
I forgot to mention that its not throwing any codes. It has a new 02 sensor, and spark plugs. I'm going to replace the distributer cap, rotor, and wires.
nycpatron
39
Apr 21, 2010 02:07 PM
