FS: Parting Out BUILT H22 Turbo Setup EK = FRESH SLEEVED H22 pistons rods head s300 injectors 3bar l
Fresh Setup! (block, head, turbo kit, h22 ek mounts, tranny, etc.!)
I am parting my H22 EK Turbo - made 450whp @ 14psi
I rebuilt the motor with sleeves this month, but plans changed!
EVERYTHING IS FOR SALE on this car (I posted it for sale a while back then had a new motor built) http://hondamarketplace.com/zerothread?id=2107906
PM me for pricing on ANYTHING (shell, turbo kit, interior, EBC, motor, etc.)
SHELL:
1997 Civic CX (lightest EK model) - Painted with 5 yr warranty - Custom Gunmetal with 12grams of silver pearl
99-00 SI Front End
NEW BALLERRR Kei Office Coilovers - 6k/8k (handles like a go-cart)
5 lug ITR Complete Conversion (rotors, pads, hubs, calipers, knuckles) with VOLK Rays Blue Lug nuts
ITR Champ White 15" wheels WITH BFG Drag Radials in the front
Fiber Images CF Hood with hood pins
CTR CF Spoiler
20% Tint with LIFETIME warranty (still have receipt)
INTERIOR: FULL INTERIOR
Passenger Air Bag Tray
99-00 SI Converted POWER WINDOWS and LOCKS (works PERFECTLY)
99-00 Door panels with SI tweeters
REMOTE START 2-way LCD Pager Alarm with extra secret kill switch :D
New Black Carpet
LS Integra Cloth Front Seats
Panasonic Headunit
New Kenwood 6x9 Rear Speakers
Momo Tuner Racing Red Stitching Steering Wheel
ITR Red Stitching Arm Rest
SI Gauge Cluster
BLOCK AND HEAD HAVE 0 MILES ON IT!
BLOCK: FRESHLY SLEEVED/MACHINED! (painted GOLD)
JG Engine Dynamics Sleeved Block done by Javier - Received it from it JG early February (2 weeks old, I have proof, you can email javier himself!)
H22 87mm CP 9:1 Pistons .20 over - BRAND NEW WITH BRAND NEW RINGS (just got piston/clearanced from Scotts Machine shop in GA) still have CP pistons box!
Crank has been micro polished - JUST RECEIVED (February 25th from Scotts Machine shop in GA, have receipt of $660.48 one day old for machining ALONE) you can even call the machine shop and verify i had everything RE machined to match!
Eagle H-beam Rods
Block is balanced
re-decked
everything!
I gave them my pistons, rods, and bearings to match everything perfectly! This block was built RIGHT! Made to handle GOBBS of power!
HEAD: BRAND NEW, cleaned and machined!
BRAND NEW FERREA VALVES put in my Scotts machine shop as well!
NEW OEM VALVE GUIDES!
NEW OEM VALVE SEALS!
CROWER valve springs
CROWER retainers
RE-surfaced, cleaned, EVERYTHING!
BRAND NEW OEM OIL PUMP
BRAND NEW OEM WATER PUMP
GASKET KIT!
TURBO KIT H22/EK:
Neukin Manifold T4 - ramhorn style - equal length
GT4088 Garrett turbo
Turbonetics Racegate Wastegate
Precision 600hp Intercooler
All t-bolt clamps, 2.5 inch piping
Greddy Type RS Blow off valve
3" downpipe
ENGINE MANAGEMENT:
HONDATA s300 - P28 - already chipped, etc. (best program and so easy to use!)
Motor MOUNTS:
H22 EKH2
TRANSMISSION:
OEM LSD M2B4 Transmission (painted GOLD) sometimes slight grind in 5th
Axles:
Hasport Axles custom for OEM LSD M2B4 Transmission
DEFI GAUGES:
Boost 52mm Amber
EGT 52mm Amber
Air/Fuel 52mm Amber
PRICESSSSSS:
1997 CX Shell - $4200 With 5 lug conversion, wheels, ITR white wheels with drag radials, tint, paint, kei office coilovers ($2000), SI conversion front end, SI power windows/locks, SI cluster, CF Hood and Spoiler, Full Interior, etc.
Block I will sell for SOLD
Head I will sell for $SOLD'
Precision 600hp Intercooler - $300 firm
Turbo Kit - SOLD
EKH2 Motor Mounts - $350
M2B4 LSD Transmission (painted GOLD) - SOLD
Hasport Custom Axles for M2b4 H22/EK - $250
BRAND NEW ARP Head studs (purchased about 2 weeks ago from vendor here) - SOLD
Used ARP Head Studs - $90
Used CP Pistons 87mm 9:1 compression/standard - $350
Defi Gauges - $330
World Electronics Boost Controller - (BOOST BY GEAR and BOOST GAUGE) - Dyno proven to hold boost better than Greddy Boost Controllers - $350
Competition Stage 5 Clutch Kit with Competition Pressure Plate and flywheel (barely used) - $250
MSD 8.5 mm Spark Plug Wires - New Cap, Rotor, AND external coil - $150
MSD Ignition 6al RED BOX (basically new, was mounted INSIDE my car - $150
Fluidyne Aluminum Half sized Radiator - SOLD
F-A-L Thin Radiator Fan - SOLD
Hondata S300 p28 ECU ALREADY CHIPPED and ready to go! - has H22 14psi Dyno Tuned MAP @ 450whp - SOLD
Conversion Harness obd2a to obd1 - $50
Skunk2 H22 Black Cam Gears - $150
SKunk2 68mm Throttle Body - B, F, H series - $220
GM 3bar Map Sensor - SOLD
RC 1000cc Injectors (barely used!) - SOLD
AEM Fuel Rail for H22 (silver) - SOLD
This was my old setup, on a different motor.
This stuff will be GONE quick, everything you need to build a car, I was spankin vettes! SO BUY FAST AND WITH CONFIDENCE!
Everything located in Atlanta
anclyt@gmail.com
AIM: anciyt
Modified by AnclyT at 9:23 PM 3/21/2008
Modified by AnclyT at 1:13 AM 3/24/2008
SHELL:
99-00 SI Front End
CTR CF Spoiler
New Black Carpet
Panasonic Headunit
SI Gauge Cluster
Eagle H-beam Rods
Block is balanced
re-decked
everything!
CROWER retainers
GASKET KIT!
TURBO KIT H22/EK:
3" downpipe
ENGINE MANAGEMENT:
Motor MOUNTS:
H22 EKH2
TRANSMISSION:
Axles:
DEFI GAUGES:
Boost 52mm Amber
EGT 52mm Amber
Air/Fuel 52mm Amber
PRICESSSSSS:
Turbo Kit - SOLD
Defi Gauges - $330
anclyt@gmail.com
AIM: anciyt
make offer on other parts too
OEM pulleys, alternator, starter, IM, tapped oil pan, fluidyne half size radiator, FAL fan, etc.
i was wondering if u sent the ic piping,taped oil pan,steel braided line fuel filter to feul rail,downpipie and catch can, bov also the clips for da injector it been bout 5 weeks already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgRaCeRB18C »</TD></TR><TR><TD CLASS="quote">i was wondering if u sent the ic piping,taped oil pan,steel braided line fuel filter to feul rail,downpipie and catch can, bov also the clips for da injector it been bout 5 weeks already</TD></TR></TABLE>
Good luck my friend.
