Engine noise coming from speakers. Please help!
Old Jul 6, 2002 | 01:53 AM
IntEgRaxbOyx415's Avatar
Default Engine noise coming from speakers. Please help!
Ive got a 97 teg with a kenwood deck and jl speakers all around. when my engine is on it makes a high pitch noise that comes out of my speakers and when i excelerate the noise gets louder. i regrounded my ground wire for my amps and deck, my power wire is not touching the rca's, and the noise is driving me crazy. please help thanks.
Old Jul 6, 2002 | 07:43 AM
b18bvtec4drteg's Avatar
Default Re: Engine noise coming from speakers. Please help! (IntEgRaxbOyx415)
You may want to re-run your speaker wires away from the power wires of the amplifier. (IE run the speaker wires on the drivers side and power & ground on passenger side) Or else you can get a noise filter (I doubt that would work) but that should solve 99% of your problems.
Hope that helps
Old Jul 6, 2002 | 10:15 AM
Calavera's Avatar
Default Re: Engine noise coming from speakers. Please help! (b18bvtec4drteg)
I was recommended a ground loop isolator that you can get at radio shack I think.
No clue if that'll solve my engine noise.
Old Jul 6, 2002 | 10:35 AM
miahmouse's Avatar
i regrounded my ground wire for my amps and deck, my power wire is not touching the rca's.
things to check
1. did you scrape all the paint off where your ground is?
2. how long is the ground wire (should be as short as possible)
3. rca's and power wire's should be seperated ie. different sides of the car, not just "not touching".
4. Some (older) amps can't be directly connected to the chassis
5. where did you ground it??
If you try everything you can think of and there's still noise, turn the gains down a little
Old Jul 6, 2002 | 03:09 PM
GSRaCeRbOI's Avatar
Default Re: Engine noise coming from speakers. Please help! (miahmouse)
do a search theres plenty of threads on this alternator whine... anyway check your grounds and see if their as short as possible and grounded on bare metal surfaces (not painted).. check the grounds at both your amp (s) and head unit.. also you might want to make sure your power wires are separated from your RCA AND speaker wires
ph0shizzle
Audio / Security / Video
Sep 7, 2006 04:38 PM
PooM
17
Jul 21, 2006 08:05 AM
xSCTYGx
Nov 11, 2003 05:42 PM
watacivic
13
Oct 13, 2003 09:41 AM
Integra99GSR
10
Sep 10, 2003 11:56 PM
