gasket replacement question (leaking)
Old Feb 27, 2008 | 09:58 AM
Rikaro's Avatar
Default gasket replacement question (leaking)
i saw my motor is leaking both engine oil and coolant. Is there a specific gasket i can replace to fix this problem? The front of the motor has oil (below the valve cover) or may be it's where the headers are.
help appreicated! thanks
Old Feb 27, 2008 | 10:01 AM
crazyguy's Avatar
Default Re: gasket replacement question (Rikaro)
i think u need to replace head gasket
Old Feb 27, 2008 | 10:22 PM
Rikaro's Avatar
Default Re: gasket replacement question (crazyguy)
thanks!
anyone else? might as well replace both head gasket and valve cover gasket
is the head gasket where the header is? or do i have to take the motor apart where the cylinders are?
Old Feb 28, 2008 | 03:48 AM
00CivicGirl's Avatar
def sounds like a head gasket..the head gasket is the gasket between the block and the cylinder head...depending on how long its been leakin or if its blown, i would have your head checked for any damage to valves, etc
Old Feb 28, 2008 | 10:07 AM
blk92_d16's Avatar
Just get a FULL gasket kit for your specific motor off Ebay and you'll be able to correct any leaks or issues for your entire motor.
E85B18
Mar 8, 2010 02:34 PM
JdmGizmo
11
Feb 16, 2008 09:32 PM
dmperdok
Jul 6, 2006 07:16 PM
sleepyIntegra
May 24, 2004 11:14 AM
XxNighthawk03xX
Feb 10, 2004 09:36 PM
