What is this pipe called?
Old Feb 27, 2008 | 07:39 AM
schumi's Avatar
Default What is this pipe called?
The metal clamp which holds the fan was rubbing on these AC pipe and there is a crack on the pipe....See the photo
What's this pipe called? Which is best place to get it? Is its easy to install?
Thanks
Modified by schumi at 11:03 PM 2/27/2008
Old Feb 27, 2008 | 07:46 AM
Jamie98RS's Avatar
Default Re: What is this pipe called? (schumi)
Yea I think theres supposed to be a rubber piece to stop it from rubbing, you would probably need to go to acura for that, just tell them its the ac line running across the rad. Hope this helps.
Old Feb 27, 2008 | 07:51 AM
jhammond_82's Avatar
Reject Papi
which pipe? i don't' see a crack. unless you mean the little one on the bottom right. that doesn't look like a fun task. i'm not sure what its called, but if your gonna replace it, you'd have to recover the ac first.
Old Feb 27, 2008 | 08:16 AM
schumi's Avatar
Default Re: What is this pipe called? (jhammond_82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote">which pipe? i don't' see a crack. unless you mean the little one on the bottom right. that doesn't look like a fun task. i'm not sure what its called, but if your gonna replace it, you'd have to recover the ac first. </TD></TR></TABLE>
Its the metal pipe that bends to the right and goes down... Its kind of in the middle of the picture. You can see the plastic electric connector just below it
derekcentrico
Sep 9, 2010 05:55 PM
miro_gt
Apr 23, 2005 08:14 PM
Kwuaymaikrup
Welding / Fabrication
Feb 16, 2005 02:46 PM
Sport_Injected
Oct 30, 2004 04:34 AM
forcedaccord95
Mar 2, 2003 08:26 PM
