TACH...
Old Feb 27, 2008 | 06:43 AM
ProjectRustyEF's Avatar
Default TACH...
i have a 90 hatch with no tach, and im trying to put a cluster with a tach. is there anything i need or is direct plug in?
thanks...
Old Feb 27, 2008 | 07:47 AM
Si-Samuri's Avatar
you have to use a 90-91 tach. any others wont be a direct fit.
Old Feb 27, 2008 | 09:49 AM
Khmi's Avatar
Default Re: (Si-Samuri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectRustyEF &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 hatch with no tach, and im trying to put a cluster with a tach. is there anything i need or is direct plug in?
thanks...</TD></TR></TABLE>
exactly
Old Feb 27, 2008 | 11:52 AM
Radim's Avatar
Default Re: TACH... (ProjectRustyEF)
I have an Auto-Meter tach it came with the car. =P. If you can't find an OEM Cluster with a Tach just buy an aftermarket used stand-alone tach from ebay. Get's the job done.
Old Feb 27, 2008 | 12:05 PM
sanimalp's Avatar
$cat /dev/urandom
Use a 90-91 cluster with a tach, then its plug and play.
Old Feb 27, 2008 | 07:55 PM
Well its plugs right in but nothing works properly....
-The speedo hits like 70 in
second....
-tach doesnt register...
-parking lights cause oil pressure light to come on...
-headlights cause check engine light...
-no other lights come on at all....
so i put the stock one back in
Old Feb 27, 2008 | 11:28 PM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
go under the faq's and search gauge.
there is a good thread about wiring.
there are even pics to help.
i found it useful, but then did it the easy way.
Old Feb 28, 2008 | 09:34 AM
Si-Samuri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectRustyEF &raquo;</TD></TR><TR><TD CLASS="quote">Well its plugs right in but nothing works properly....
second....
so i put the stock one back in </TD></TR></TABLE>
Are you sure its a 90-91 tach. they look the same as 89 and have same plugs but dont work the same.
Old Feb 28, 2008 | 09:39 AM
grog's Avatar
Default Re: TACH... (Si-Samuri)
this shouldnt have happened if its the correct one, so it must be the wrong cluster.
Old Feb 29, 2008 | 06:23 AM
OH i see then....well thanks for the help.....
Old Mar 1, 2008 | 11:36 AM
jdm27ef's Avatar
or just buy those 5" tach at the shops or craigslist
Old Mar 1, 2008 | 04:29 PM
dblock8989's Avatar
Default Re: TACH... (jdm27ef)
If U wantg try eBay They got some 5'' and 7'' tachs for cheap about 40-50.00 bucks
Old Mar 3, 2008 | 10:49 AM
Default Re: TACH... (dblock8989)
the 88-89 cluster is different from the 90-91 cluster
just buy the exact same year crx cluster and it should be plug and play.
the only time the tach pods look good is if it is man trans(kinda gay if auto)
Fatcobra
Apr 17, 2007 05:20 AM
EK k kay
Sep 3, 2005 11:02 PM
joenationwide
Jul 18, 2004 01:22 PM
Sketch_hs
May 12, 2003 07:11 PM
