Suspension & Brakes Theory, alignment, spring rates....
Changing spring rates
Old Feb 27, 2008 | 05:18 AM
b16a1eg6's Avatar
Default Changing spring rates
Currently I have 700-250-550 Ground controls in my Civic. I want to go to a 700lb rates. But they don't offer it in a 7" 2.5id spring. They do offer it in a 8" 2.5id spring. Would that be good to add an inch and just lower the spring perch buy an inch?
Old Feb 27, 2008 | 06:59 AM
omnirage's Avatar
Default Re: Changing spring rates (b16a1eg6)
Yup.
Old Feb 27, 2008 | 11:16 AM
Tyson's Avatar
or a 6" spring would be fine. depending on your desired ride height. you really will just subtract or add an inch to the perch position it is at with the same spring rate.
Old Feb 27, 2008 | 11:30 AM
meb58's Avatar
Default Re: Changing spring rates (Tyson)
Check block heights too...when selecting higher rates within a given length, the block height becomes shorter due to thicker coils. You simply need to make sure the new heavier rate springs have enough travel for your application.
Eibach's website has a great spring chart. Pick a 7" spring for goofs and giggles and see what happens to the block height when you change the rate - up or down.
good luck
Understeer
71
Dec 19, 2007 08:57 AM
pjr710
Suspension & Brakes
19
Apr 19, 2007 02:44 PM
Jhonny Ricer
Suspension & Brakes
Mar 29, 2007 03:30 AM
P@@RB@Y
Suspension & Brakes
Dec 26, 2005 08:38 AM
Fuel
May 3, 2004 01:25 AM
