skunk2 pro cams stage 1 ?
Old Feb 27, 2008 | 12:02 AM
ekblacknight's Avatar
Default skunk2 pro cams stage 1 ?
Can I just get some valve springs or do I have to get retainers too? I have a h22 I been told I just need to buy valve springs dont know if this is safe any feedback will be great.
Old Feb 27, 2008 | 12:20 AM
Combustion Contraption's Avatar
OEM retainers will lead you to have ret. to valve stem seal clearance issues. I would use aftermarket retainers, personally.
Old Feb 27, 2008 | 07:47 AM
Default Re: (Combustion Contraption)
thats what I thought but they told I wont be rev that high in a h22 I max out at 7600 rpm, but thanks for the input
Old Feb 27, 2008 | 07:53 AM
allmotorsecret's Avatar
i have been using stock retainers for the past two years on my sks2 but i heard that with the pro series you should use all pro series valvetrain
h22crxpwr's Avatar
Default Re: (ekblacknight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekblacknight &raquo;</TD></TR><TR><TD CLASS="quote">thats what I thought but they told I wont be rev that high in a h22 I max out at 7600 rpm, but thanks for the input </TD></TR></TABLE>
pro 1's i would definitely run complete valvetrain.. and you will be building power to a little over 8000. shifting at about 8100 to 8300. Is this a stock motor? what else do you have done to it?
what do you mean you max out at 7600? rev limiter at 7600? by the way you will need to get tuned with those cams. What ECU are you running?
Old Feb 27, 2008 | 10:13 AM
Default Re: (h22crxpwr)
I havnt put the cams in yet but the bottom end is stock, might get some headwork done and 7600 is were I shift at because I lose power after 7700 rpm
Old Feb 27, 2008 | 10:16 AM
h22crxpwr's Avatar
What Ecu are you running? with the cams like i said you will be shifting at 8200 or so at the track. do you have a tuner in mind yet to dyno after you put the cams in? since you are In Riverside you can go to Chris at Whitfield racing. he's great at Crome tuning. we made 210 on his dyno with a stock h2b with ebay header and intake tube, and pro 1's.
Old Feb 27, 2008 | 02:28 PM
my bad im running chrome I got it from Chris at Whitfield racing I had my car dyno there last year when all i had was a stock h22 with ebay headers and intake put out 179hp not 2 bad for stock car but Im back in the game what to put down some good numbers these time u know
Old Feb 27, 2008 | 02:54 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekblacknight &raquo;</TD></TR><TR><TD CLASS="quote">my bad im running chrome I got it from Chris at Whitfield racing I had my car dyno there last year when all i had was a stock h22 with ebay headers and intake put out 179hp not 2 bad for stock car but Im back in the game what to put down some good numbers these time u know </TD></TR></TABLE>
for sure the cams will help a LOT.. you should be right at or over 200 no prob. and get the complete valvetrain. we ran the tuner series valvesprings and retainers with no problems whatsoever. even with misshifts to 9000+ rpm !!!
Old Feb 27, 2008 | 03:23 PM
What are the lift/dur. specs of the H22 Pro1's?
Old Feb 27, 2008 | 04:06 PM
i dont know the specs on the cams
Old Feb 28, 2008 | 07:18 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">What are the lift/dur. specs of the H22 Pro1's?</TD></TR></TABLE>
they are on Skunk2's website.
Old Feb 28, 2008 | 12:16 PM
I know this, I was seeing if the thread creator even knew what he was putting in his engine.
ej_jake
Feb 15, 2018 08:28 PM
slowesteg
Apr 21, 2014 11:51 AM
ArmaanOG
Aug 6, 2009 06:59 PM
AznBlueBoy
Apr 28, 2006 09:20 AM
pr0digy1
Mar 17, 2004 06:49 PM
