Suspension & Brakes Theory, alignment, spring rates....
How to raise without coilovers?
Old Feb 26, 2008 | 08:58 PM
commutercar's Avatar
Default How to raise without coilovers?
I have a ef civic with neuspeed race springs and koni shocks. I like to ride quality and handling but the height is causing me to scrap and damage my headers. The springs are sitting on the highest positiion of the shocks. I would ideally like to get an inch raise. Is there anything I can do such as putting a thicker spring cup or a spacer of some sort to get some additional height? I really don't want to change my springs. Thanks.
Old Feb 27, 2008 | 07:04 AM
EK_B's Avatar
Default Re: How to raise without coilovers? (commutercar)
It might be not safe, but PepBoys sells spring spacers that you could try.
Old Feb 27, 2008 | 07:28 AM
Relic1's Avatar
Best way to go, sell the springs and get different ones. (or trade)
second best, install a firm rubber spacer between the upper mount and spring. It has to be thin enough to prevent the spring from slipping out of the cup though.
third best, spring spacers that go between the coils. But they will cause the car to be a little less predictable over large bumps due to one portion of the coil having a different rate than the rest. And there is the possibly of causing the coil to bind and possibly bend/break if you bottom out a lot.
Old Feb 27, 2008 | 10:24 AM
TunerN00b's Avatar
Old Feb 27, 2008 | 11:13 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commutercar &raquo;</TD></TR><TR><TD CLASS="quote">I have a ef civic with neuspeed race springs and koni shocks.
I really don't want to change my springs. Thanks.</TD></TR></TABLE>
change your springs. your welcome.
Old Feb 27, 2008 | 02:40 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commutercar &raquo;</TD></TR><TR><TD CLASS="quote">I have a ef civic with neuspeed race springs and koni shocks. I like to ride quality and handling but the height is causing me to scrap and damage my headers. The springs are sitting on the highest positiion of the shocks. I would ideally like to get an inch raise. Is there anything I can do such as putting a thicker spring cup or a spacer of some sort to get some additional height? I really don't want to change my springs. Thanks.</TD></TR></TABLE>
Change your springs.
If you don't, you'll regret not doing it later on.
Crazydave's Avatar
Default Re: How to raise without coilovers? (Tyson)
Don't the koni shocks have circlips with different mounting heights?
If not , then get some nuespeed sports or eibach pro kits.
I really like the Neuspeed sofsports or the H&R OE springs
Old Feb 27, 2008 | 09:51 PM
Thanks guys for the input. I guess will have to start looking for some different springs. Thanks again.
ribal_gh
Suspension & Brakes
Feb 28, 2013 12:52 PM
accord03coupe
Oct 6, 2006 07:04 PM
abercrombemonkey
Suspension & Brakes
Oct 1, 2005 08:23 AM
Simon_the_Pieman
Feb 5, 2002 06:47 PM
